boon racoon Posted March 8, 2005 Report Share Posted March 8, 2005 I have a KMC thin chain (off supercycles..it's to be run with gears) How do I go about joining it? I have got these connecter links..so I shorten it then put these on to join it? Or can i do away with these and join it at a male/female end with black pins that are already in there? Wanna know which is the more common / stronger way of doing it cos I don't wanna end up with a dodgy chain. Cheers Boon(e) Quote Link to comment Share on other sites More sharing options...
T-Limburn Posted March 8, 2005 Report Share Posted March 8, 2005 I have a KMC thin chain (off supercycles..it's to be run with gears) How do I go about joining it? I have got these connecter links..so I shorten it then put these on to join it? Or can i do away with these and join it at a male/female end with black pins that are already in there? Wanna know which is the more common / stronger way of doing it cos I don't wanna end up with a dodgy chain. Cheers Boon(e) ← personally i donot use the connector links, i just shorten it and then join it by using the pins that 'are already there in there' Quote Link to comment Share on other sites More sharing options...
Brisa Posted March 8, 2005 Report Share Posted March 8, 2005 Yea, don't bother with the connector. Just join it like you would a normal chain... Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted March 8, 2005 Report Share Posted March 8, 2005 the kmc connector is a stong beast! when my kmc kool chain snapped it did so at the middle of the chain, so that isnt a problem :D i wouldnt join it with a chain tool because you wont get it as strong as all the other links that a machine has joined. and the weakest link is the one thats gunna snap :D cheers. Will P.S. which version of the chain is it? thin? fat? Quote Link to comment Share on other sites More sharing options...
T-Limburn Posted March 8, 2005 Report Share Posted March 8, 2005 P.S. which version of the chain is it? thin? fat? ← I have a KMC thin chain (off supercycles..it's to be run with gears) ← Quote Link to comment Share on other sites More sharing options...
rich4130 Posted March 8, 2005 Report Share Posted March 8, 2005 The connector link catches in the mech as well, no need unless you take it off lots. Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted March 8, 2005 Report Share Posted March 8, 2005 I joined my KMC with a chain tool, and since then I have had to replace my tensiles for a few reasons including the fact I had twisted all the chainring bolts backwards, but the kmc is fine. So chain tool it is. Quote Link to comment Share on other sites More sharing options...
Matt_Tupman Posted March 8, 2005 Report Share Posted March 8, 2005 Chain tool :D the connectors are weak :D Quote Link to comment Share on other sites More sharing options...
JT! Posted March 8, 2005 Report Share Posted March 8, 2005 I don't use the conector, i just use a tool, with the pins. (N) Quote Link to comment Share on other sites More sharing options...
Dr. Nick Riviera Posted March 8, 2005 Report Share Posted March 8, 2005 is the kmc like a sigma conenctor? if so avoid like bubonic plague and 1100+ wheelbases Quote Link to comment Share on other sites More sharing options...
robonatomz Posted March 8, 2005 Report Share Posted March 8, 2005 if you got a good chain tool use that but the conector's aint that week. i use them if im in a rush or somthing. but would prefer the proper joining way. just be carefull not to split the outer link when re joining the chain, i found that kmc's somthimes do that. Quote Link to comment Share on other sites More sharing options...
CalopS Posted March 8, 2005 Report Share Posted March 8, 2005 dont use the link, mine snapped and i banged my knee on the stem and couldnt walk very well for 3 days :D Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted March 8, 2005 Report Share Posted March 8, 2005 hmm mixed views :D i was talking about the fat version when i said mine snapped in the middle of the chain. im guessing the thin quicklink is not very stong then. go with a decent chain tool :D Will Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 8, 2005 Report Share Posted March 8, 2005 The quick link isnt as strong as the main links. I'd go without it, use a normal chain tool Matt :D Quote Link to comment Share on other sites More sharing options...
011001000110010101110010 Posted March 8, 2005 Report Share Posted March 8, 2005 Chain tool again :D Been running mine for about a year no problems. Quote Link to comment Share on other sites More sharing options...
Wayne-king Posted March 8, 2005 Report Share Posted March 8, 2005 Chain tool :D the connectors are weak :D ← yep, guess where my old KMC chain snapped? (N) Quote Link to comment Share on other sites More sharing options...
Felix Posted March 8, 2005 Report Share Posted March 8, 2005 I snapped many chains, but never at the connector. Quote Link to comment Share on other sites More sharing options...
