Help/advise Please Lads
mavic
Hay all, Well i have had my hope mono rear hub for about 1.5 years,andit has run
amazing for that time, untill the other week when i started having some trouble.
i will try and exsplain :)
I was riding down a hill to town and the hub started getting stuck ( only when free wheeling) then i would have to pedal for a bit to un stick it, the hub now catches on what seems a point in side and the chain jolts :) , i have no problem with engagements or anything but i think its gonna die soon.
i think i will have to send it back to good old hope.
But what is it lads is the free wheel going???
i have givern it a survice and have found that i am missing 1 engagement tooth
but mmm.
helps fellow trials riders
( as you can see im not too good with hubs.).
thanks
ecodan.
Faire enough mr tart (Y)
You know what is causing this to happen though just woundering.
Yep, harsh landings (well, trials in general). The axle flexes, causing the freehub body to slam into the ratchet. Their new hub will help prevent this, should be a lot tougher :)
Man i got no money so if i send it too them anychance of them sending it back free :"> ???.
