squince Posted March 6, 2005 Report Share Posted March 6, 2005 My 2005 echo rim is cracked on the join, is this bad?. It is cracked on either side where the join is. If it is bad would it be under guarentee? I got the rim on a bike of phil williams. cheers andy Quote Link to comment Share on other sites More sharing options...
BI-KING Posted March 6, 2005 Report Share Posted March 6, 2005 It should be ok if you keep the spokes tight, it happens to alot of rims but doesnt really affect their preformance, so it should be fine :) :) Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 6, 2005 Report Share Posted March 6, 2005 My 2005 echo rim is cracked on the join, is this bad?. It is cracked on either side where the join is. If it is bad would it be under guarentee? I got the rim on a bike of phil williams. ← The rims are pinned at the join, so there is always a 'crack' showing. Unless you've dented it? In which case, pull the dent out and grind back over it, it will be fine :) Quote Link to comment Share on other sites More sharing options...
squince Posted March 6, 2005 Author Report Share Posted March 6, 2005 Cheers thanks alot, thats one thing of my mind. I took it apart because the spokes were all snapping. Im going to build it back up with some stronger spokes. cheers andy Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 6, 2005 Report Share Posted March 6, 2005 I took it apart because the spokes were all snapping. ← :) Crikey. A decent wheelbuild will prevent spokes snapping more than having better spokes, if you get me. Either way, good build + decent spokes = good strong wheel :) Quote Link to comment Share on other sites More sharing options...
FAT~DAN Posted March 6, 2005 Report Share Posted March 6, 2005 :lol: Crikey. A decent wheelbuild will prevent spokes snapping more than having better spokes, if you get me. Either way, good build + decent spokes = good strong wheel :) ← one of my mates wheels was built by you and every time he went to backwheel the back of a bench back not even hiting the rim a spoke would snap about 2-3 times this happened but its ok now i think Dan Quote Link to comment Share on other sites More sharing options...
Tartridge Posted March 6, 2005 Report Share Posted March 6, 2005 Sounds interesting. Who's wheel is it? What rim and hub? How old is the wheel? He should have spoken to me :) Quote Link to comment Share on other sites More sharing options...
JTM Posted March 6, 2005 Report Share Posted March 6, 2005 On any pre-built bikes where the wheels are built by a machine, the wheels always going to need a bit of tweaking at first. I assure you phil builds the bikes up to a top standard and tries to have a go at tensioning each wheel, but he's only just getting selectbikes.com off the ground so things are a bit hectic round his ways (in his warehouse/mahoosive shed anyways! :) ) Quote Link to comment Share on other sites More sharing options...
