Booster To Fit My Revell.
b'mouth trials
When I was building my revell I wanted to use my normal 2 bolt booster but then realised that it was not wide enough! :(
Does anyone know which 4bolt booster will fit it because I don't want to buy a echo or rb for example and find that it doesn't fit, and I really want a booster to stop my brake being sooooooo spongy (Y)
Cheers, Aaron ;)
ask clive at leeson bikes if he will make you a booster top fit your revell!
these are seriously good boosters!
if not see if the big bulky echo conrtol would fit!
OR try and find a shimano xtr booster :(
the only 3 boosters i recon i would use
What distance are the mounts apart?
This was really dodgy measuring and I could be waay off but at the top it looked like about 100mm and at the bottom it was about 103mm :) .
I was thinking of making one myself but I'm not sure if I can be arsed :) :( .
Cheers, Aaron.
Edited by b'mouth trials
im pretty sure 4 bolt mounts are 100mm apart whereas 2 bolt are 80mm :( (i measured several bikes and found these were the common measurements for my as level design coursework-give or take a few mm!!)
any 4 bolt booster will fit as far as im aware of and obviously you cant fit a 2 bolt 1 on..... (Y) so no xtr booster for you
try an echo contro boosterl-they look beastly and cant be worse than an rb (ok rbs arent that bad but do flex alot still)
personally i dont think you can beat making your own :)
(Y)
