Pc Help Needed
Nick Dale
Ok,
Everytime i try to open my computer or my documents or any folder of the sort it
comes up and the goes again and then all of the desktop icons vanish and the quick
launch items and anything that is open will vanish and the tool bar at the bottom will go
as well and then it will all come back up again a couple of seconds later i ran a virus
check and it found 2 virus's got rid of one and wasn't able to get rid of the other one and
i cant get to it because it is in documents and settings nd i hae to go through my
computer to get to it :( Does anyone know what i can do or how to fix this problem?
I tried restarting my P.C and all sorts but i just don't know what to do :)
Any help is much appreciated(sp?) Nick. :(
Unfortunatly it sounds like there's not a lot you can do but format it.
Have you tried starting it up in safe mode? If you do it this way, there may be a chance you can get to your files and stuff and copy them to another stoarge medium, so all your data isn't lost.
From the way you've explained it, I'm guessing the virus you can't remove is a file somewhere in your documents. If you are looking to delete it, try using DOS to get to the file, that might get around the disappearing windows...
If not then it looks like formatting is the only way :(
