Converting Music To Mp3
Dan Hardman
Does anyone no how to convert music from my cds and that is stored on media player into mp3 as i need to whack it all on the mp3 player.
I must add the mp3 player is perfect
micheal stop using my fecking account :blink: if you want to know how to convert it you may as ewll just ask me you idiot
no, what happens is when you transfere from a cd to your comp via media player it saves the files as .acc not .wma or .mp3
It shouldn't do! WMP uses wma. Actually, now it looks like you can rip to MP3 with WMP10 :)
Every time i have done it i just changed the extension.
It works, lol.
No it doesn't... the extension is meaningless to file format. The only reason this can make any difference is because windows isn't smart enough to tell the difference between files based on anything beyond the extension. If you rename a .mp3 file to .wma it still won't work in something without the mp3 codecs!
Isn't .acc the iTunes filetype? Actually now that I think about it that's .aac, .acc is some form of windows executable file format, which should certainly not be being used for music files. Are you sure it's not .aac?
