OnzaNewbie Posted March 2, 2005 Report Share Posted March 2, 2005 Hey all, I don't really know how to explain it But when I go to adjust the pads with the red turny bit it has stopped adjustin the pads, and its annoying me, Please help me (Y) Cheers Marc Quote Link to comment Share on other sites More sharing options...
TheMunn Posted March 2, 2005 Report Share Posted March 2, 2005 Maybe the TPA is fully wound out, you should try un-winding it and setting your brake up again, then see if your TPA still work's. Quote Link to comment Share on other sites More sharing options...
Davetrials Posted March 2, 2005 Report Share Posted March 2, 2005 Sounds like a goosed tpa, theres a post about bodging it in the FAQ. Quote Link to comment Share on other sites More sharing options...
OnzaNewbie Posted March 2, 2005 Author Report Share Posted March 2, 2005 Cheers, I've got it sorted now, expect I need to get a bolt to put in it Marc (Y) Quote Link to comment Share on other sites More sharing options...
Davetrials Posted March 2, 2005 Report Share Posted March 2, 2005 4mm 4 bolt magura bolt. Quote Link to comment Share on other sites More sharing options...
JTM Posted March 2, 2005 Report Share Posted March 2, 2005 Its a m5 thread dave you goose Quote Link to comment Share on other sites More sharing options...
Davetrials Posted March 2, 2005 Report Share Posted March 2, 2005 Balls i thort that was a vee brake mount bolt type thing Quote Link to comment Share on other sites More sharing options...
Tartridge Posted March 2, 2005 Report Share Posted March 2, 2005 Its an M5 thread you goose (Y) Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 2, 2005 Report Share Posted March 2, 2005 If you're running two Maguras, piss the other one off by changing it when you changed your raped one. It's going to happen, so you might as well pre-empt it. Plus, I've got more movement now with mine due to the longer bolt, so I can be nicely lazy setting up, even though I still spend a while every Saturday making sure it's all rockin' \m/ Quote Link to comment Share on other sites More sharing options...
guy Posted March 2, 2005 Report Share Posted March 2, 2005 sure you dont need to reblled you brake marc? that prob the reason you have run out of tpa usage vage attemt to help guy Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 2, 2005 Report Share Posted March 2, 2005 I wouldn't have thought it'd be have stopped the TPA moving though? It'd just make the brake feel ultra mushy, as opposed to shearing the TPA bolt, which is what sounds as if it's happened (Y) Quote Link to comment Share on other sites More sharing options...
guy Posted March 2, 2005 Report Share Posted March 2, 2005 well hes run out of tpa he cant move it more but he can move it back so i would imagine he needs a bleed but meh i duuno Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 2, 2005 Report Share Posted March 2, 2005 If the bolt has sheared, you'll be able to move it away from the sheared section of bolt remaining inside the lever body itself, but when you try and tighten it up, it'll not be able to move it, thus stopping it moving. Quote Link to comment Share on other sites More sharing options...
OnzaNewbie Posted March 3, 2005 Author Report Share Posted March 3, 2005 well hes run out of tpa he cant move it more but he can move it back so i would imagine he needs a bleed but meh i duuno ← No I tryed that, it didn't work They are sorted now cause shaun told me how to do it over msn and a webcam :S Cheers Marc :( Quote Link to comment Share on other sites More sharing options...
