Magura Hosing
Sam Nichols
Outer cable isn't expensive, so go buy some.
Outer cable isn't expensive, so go buy some and stop asking such silly question's.
:">  Sorry for double post.
Triple post!!
I know outer cable isn't expensive, I work in a cycle shop so i get it free!
I'm just wondering about maggy hosing for the friction side of things. I.E. Smoother brake.
Would the hosing fit into the 'lil ferruls they fit into?
They may well be smoother, though as they wern't designed to take a cable the smoothness may not be suited to metal, but suited more to a fluid.
Also i recon there'd be alot of compression as they're not as stiff as normal cabling.
Apparently mech cabling is stiffer than brake cabling so that might be worth a try at some point.
Good idea though (Y)
EDIT: The Mag hosing is alot wider in diameter compared to the standard cabling. So the inner cable would have more freedom inside the hose, but i'm not sure if this is a good thing or a bad thing really?
Edited by N.Wood
Triple post!!
i think so long as there was no major bends in the hose the cable wouldnt produce excess friction. And you would have to use lots of grease/lube etc. so theres as little friction as possible.
but i think the best way to go about it is to just try (Y)
even normal outer is a bit squidgy....
use that metal stuff benlee has/had on his avid disc....cant remember the name though :turned:
I have no idea on his specific bike, but it might be Nokon stuff?
I think it's Avid full metal jackets...
I just thought it might've been an idea, but since mikes already tried and it was poor - theres no point me trying :P
odyssey cables for me then!
Edited by nichols_sam
