Magura Evo Mounts?
Bigman
Righty then, i have been using evo mounts now for coming on a year now, i have filed the tabs off the top so that they will clamp tighter on the cylinder, i have also fitted new plastic rings, the problem i am having now is that the right hand cyclinder is insistent on moving, still, even when tighten down as thight as i can get the mounts, this is realy starting to annoy me, can somebody help?
Adam
PS: i am running 35mm coust pads, not 50mm standard pads.
yeh, that is what i was thinking Adam, roughen the mounts up, and try another set of the new rings i have got, ah well, we will see.
Adam
ye it's best to use some new rings as you say you have, After a while they get indented with the thread too much which doesn't help, also, the new rings help setting the brake up again which is always welcome.
Phil.
