5.1 Suround Sound Speaker Problem
Ingram
Hi, I recently bought some phillips 5.1 surround sound speakers and sound card. The speakers are recomended for this card anyway, Down to the problem. When i use the program change the settings of the speakers (equalizers, atomsphere and stuff) i go to the tes bit thre and it goes round all the speakers good, front left, yep comes out front left, centre yep comes ou tthe centre and so on. How ever when i use the speaker test in Counter-Strike: Source when it gets to "rear right" it plays out the front left as well and when it plays the rear left it plays it out the front right to :closedeyes: the front ones play on there own so why don't the back (Y) i chaged around the devices for the play back (before it was playing out every speaker when the individual ones was being played) but i chanmged the default device and got it to that what i explained above, Can slomeone help me out please i dont get how it works perfectly on the program but not on CS: Source, Thanks alot guys, apreciate it, Cheers. Jake
And it works properly in Windows however? (Sorry if youve said this in your original post but i found the way you worded everything really confusing!) Does 5.1 sound work fine in everything EXCEPT source!?
Either way go to Control Panel -> Sounds & Audio Devices -> Advanced
make sure the speaker settings dropdown says 5.1 speakers.
