Would Like A Few Bits Of Infomation On
Ingram
hey, basically i would like a few bits of infomation on the zoo! pitbull, Basically is it realy hard to manual and once you get the front ene up will it stay up easier than my Megamo Radical (Stock) Also, I am aware that im not going to be able to bunny hop as high but is there going to be a significant decrease in height? Thanks alot for all your help, apreciated, Jake
It will feel different to manual. The back end of the Zoo is guna be shorter than that of the Megamo, this will make the bike "quicker" on the back wheel, if you get me. :- Like when your on the backwheel, the bike should feel easier to keep there and more controlled because of the shorter back end.
Again, you should be able to bunnyhop just as high, it will probably just feel different at first, but you should get used to it.
stan.
