scotty-trials Posted February 17, 2005 Report Share Posted February 17, 2005 Well it keeps coming loose every 10.15 min and its sending me Crazy! :huh: So as i dont know anyone who can weld. would soldeing work? I know it proberly wont but im just making sure. Any other sugestions. Scotty :huh: Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted February 17, 2005 Report Share Posted February 17, 2005 Locktight it :huh: Quote Link to comment Share on other sites More sharing options...
scotty-trials Posted February 17, 2005 Author Report Share Posted February 17, 2005 Locktight it :huh: ← Sorry forgot to say ive tried. Scotty :huh: Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 17, 2005 Report Share Posted February 17, 2005 Sorry forgot to say ive tried. Scotty :huh: ← Which brand of loctite? How much? Did you clean away any grease first? Loctite works perfectly, you just have to do it right :huh: Quote Link to comment Share on other sites More sharing options...
scotty-trials Posted February 17, 2005 Author Report Share Posted February 17, 2005 Which brand of loctite? How much? Did you clean away any grease first? Loctite works perfectly, you just have to do it right :huh: ← It was a dear one. Corish dad gave it us. Its a VW engine locktight for the bolts. so its pretty good shit. Would soldering work. And Corish has used it. and it wo perfect for him. Scotty :huh: Quote Link to comment Share on other sites More sharing options...
nb88 Posted February 17, 2005 Report Share Posted February 17, 2005 If it didnt work, you didnt do it right. Make sure you clean all the threads properly with petrol or something before applying it, and apply a small amount to the lockring, then screw it on and wait for around 30 mins until riding again. Has worked fine for me loads of times matey Quote Link to comment Share on other sites More sharing options...
Backgren Posted February 17, 2005 Report Share Posted February 17, 2005 (edited) weld it :huh: you wont be able to open it , if you dont grind away the welding, but that doesnt matter. spray lube it whenever needed. works fine. could show where to weld, if thats not obvious. Edited February 17, 2005 by Backgren Quote Link to comment Share on other sites More sharing options...
Brisa Posted February 18, 2005 Report Share Posted February 18, 2005 Got mine welded up on tuesday, seems to have done the trick... I assembled it using Dax wax hair stuff (to keep the bearings in) and i think its got all through it .... :( A question ACS related to save making a new topic: Do profiles use leaf springs like ACS freewheels? If so are they any stronger, AND if they are will the have the wee bit that goes into the whole to keep it in place? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 18, 2005 Report Share Posted February 18, 2005 Do profiles use leaf springs like ACS freewheels? If so are they any stronger, AND if they are will the have the wee bit that goes into the whole to keep it in place? ← First question - yep, they do :( 2nd question... not sure what you mean, but i hope these can be of use: http://tartybikes.users.digital-crocus.com...fileratchet.jpg Cheers, Adam Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted February 18, 2005 Report Share Posted February 18, 2005 That looks alot like my ENO.....to save a new topic- where can i get new pawls for an ENO (trials) freewheel? cheers, adam Quote Link to comment Share on other sites More sharing options...
