Car Lights...installing
Joe Papasnap Maher
Right, i got one sdie in , all works fine and dandy, but on the other side, there is some big gay phat thing sat right by where i need to install the lights...and i cant get the cover off :D
i can undo it, but it only moves away alittle bit and i cant actually get it out to get to the lights :P
any idea....
Should i just jank it out....??
also theres a few wires stoping it from moving aswell..
Surly there must be a way of getting it off..? :S :)
right new problem...
Got the cover on....
turn lights on...light dont come on
so...give it a fiddle
and it works...???
Then, i put main beam on, and the light went off, gave it a wiggle, and still no light :S
Loose connection or do u think i blown the bulb from the amount it kept hitting the side when i was trying to get the the cover over it??
With the next ones be really sensative.. they dont take much abuse. You will know if its blown by looking at the small wires in the bulb, chances are they arent toughing anything if been handles roughly.
l-----l
l l
l l
Wee diagram of inside the bulb.. the dotted line should touch both sides and not be cracked etc...
