Is It Possible?
Siders77
I'm presuming they're the ones that come on the t-pro, type ones?
If so, clive could probably do it, won't cost too much.
Just give him a phone. (Y)
Mike.
They might still be alu legged.....
As people have said the most cost effective thing is probably to sell your forks and buy some with a disk mount.
Well, the T-Pro standard forks are cromo so it should theoretically be possible. I doubt Clive would do it - he's not happy putting disc mounts on his forks 'cos he reckons it weakens them too much, let alone putting them on another companies fork's? Either way, they'd probably be too weak. In the same way that "disc compatible" frames snap like kindling because companies just make a frame then buy an off-the-shelf disc mount and weld it on and break, the forks would do the same thing. Just save up a bit and buy some disc forks. Monty do some for £35-ish, so go for them?
Mark.
