Bonney@X-Street Posted February 4, 2005 Report Share Posted February 4, 2005 Right well basicly, this image comes up when i first install photoshop..have installed 3 times now and it still comes up with this all of the colour pallettes are pink, including monochrome :blink: so all images have a damm pink layer over them, any ideas how to cure? Bon Quote Link to comment Share on other sites More sharing options...
Simon Posted February 4, 2005 Report Share Posted February 4, 2005 The scratch disk, is basically the hard drive it uses to dump all its memory allocations. You have to set this to a different hard drive to what photoshop is installed onto. This can be done in Preferences. For the colours, first of press "D" on your keyboard, to reset the colour's, if this does'nt work, go to "Image" menu (at the top, next to edit) and in one of the first secondry options, is "RGB colour" or similar, select that if it is'nt already selected. Quote Link to comment Share on other sites More sharing options...
Bonney@X-Street Posted February 4, 2005 Author Report Share Posted February 4, 2005 right i have done everything listed above and its still pink, as much as pink is cool, dont really want it. i only have one hardrive so i have no idea what it could be :blink: Quote Link to comment Share on other sites More sharing options...
Corish Posted February 5, 2005 Report Share Posted February 5, 2005 (edited) press Q ? Very much doubt it as I've just tried it in photoshop my self. Worth a little try though. corish Edited February 5, 2005 by Corish Quote Link to comment Share on other sites More sharing options...
Bonney@X-Street Posted February 10, 2005 Author Report Share Posted February 10, 2005 ok, still not sorted.....any other ideas? Quote Link to comment Share on other sites More sharing options...
love_trials Posted February 10, 2005 Report Share Posted February 10, 2005 nt too sure myself, bt PM sexymike, i know he had the same problem when he installed it. not one hundred percent sure as to whether he fixed it, but its worth maybe giving him a shout?? Quote Link to comment Share on other sites More sharing options...
deagledaddy Posted February 10, 2005 Report Share Posted February 10, 2005 The scratch disk, is basically the hard drive it uses to dump all its memory allocations. You have to set this to a different hard drive to what photoshop is installed onto. This can be done in Preferences. For the colours, first of press "D" on your keyboard, to reset the colour's, if this does'nt work, go to "Image" menu (at the top, next to edit) and in one of the first secondry options, is "RGB colour" or similar, select that if it is'nt already selected. ← I've not set mine to different hdd and i have no pink problems as far as i am aware :rolleyes: bizzare... I thought it ws just due to memory usage etc. Quote Link to comment Share on other sites More sharing options...
Simon Posted February 10, 2005 Report Share Posted February 10, 2005 I've not set mine to different hdd and i have no pink problems as far as i am aware :rolleyes: bizzare... I thought it ws just due to memory usage etc. ← No, my using a different hard drive reply was related to the "swap disk" problem. You don't really need to select a different hard drive, but another folder atleast. Already suggested what i know for the pink issue. Tried a photoshop forum? Or even google. Being photoshop is such a widely used program, theres probably atleast one other out there with the same problem as you. Quote Link to comment Share on other sites More sharing options...
Tomm Posted February 10, 2005 Report Share Posted February 10, 2005 You don't NEED to change the scratch disk. I've just left it as it is and it works fine. Maybe on slower PCs/more intensive work it'd make a difference. Don't worry about it. Quote Link to comment Share on other sites More sharing options...
Bonney@X-Street Posted February 25, 2005 Author Report Share Posted February 25, 2005 right bit of an update: The problem was my monitor profile. Went into control panel and ran adobe gamma and boom....all sorted! so if anyone has the same problem...thats what you have to do (Y) Bon Quote Link to comment Share on other sites More sharing options...
