Corish Posted January 31, 2005 Report Share Posted January 31, 2005 Will Dot 3 / 4 fluid work??????? corish Quote Link to comment Share on other sites More sharing options...
Dan Hardman Posted January 31, 2005 Report Share Posted January 31, 2005 dot will burn the seals in maguras, only mineral can be used in them Quote Link to comment Share on other sites More sharing options...
Corish Posted January 31, 2005 Author Report Share Posted January 31, 2005 So can I use water and antifreeze cos u can use them in mag hs33's n there mineral oil? Corish Quote Link to comment Share on other sites More sharing options...
tank_rider Posted January 31, 2005 Report Share Posted January 31, 2005 dot fluid will dissolve the seals. if its for a trials brake and you dont like stoppies or big hills then use water as a temporary measure. else get some mineral oil. Quote Link to comment Share on other sites More sharing options...
Dan Hardman Posted January 31, 2005 Report Share Posted January 31, 2005 water would boil if used in a disc brake Quote Link to comment Share on other sites More sharing options...
Corish Posted January 31, 2005 Author Report Share Posted January 31, 2005 water would boil if used in a disc brake ← Well we'll put water in he don't use his brake all that often. also its a mod so its not capable of going that fast either. Doesnt anti-freeze stop things gettin too hot also :( :D :P :- :( Doubt it but im sure I read it does, anyway how do I bleed it without a kit? Corish Quote Link to comment Share on other sites More sharing options...
Dan Hardman Posted January 31, 2005 Report Share Posted January 31, 2005 no, anti freez stops is freezing :( not boiling :( Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted January 31, 2005 Report Share Posted January 31, 2005 Antifreeze does also increase the boiling point of water if memory serves me correctly... Dave Quote Link to comment Share on other sites More sharing options...
Dan Hardman Posted January 31, 2005 Report Share Posted January 31, 2005 whats the boiling point of vokda? or pure alcohol Quote Link to comment Share on other sites More sharing options...
dave85 Posted January 31, 2005 Report Share Posted January 31, 2005 whats the boiling point of vokda? or pure alcohol ← 97 celcius Quote Link to comment Share on other sites More sharing options...
trials_pimp Posted January 31, 2005 Report Share Posted January 31, 2005 Antifreeze does also increase the boiling point of water if memory serves me correctly... you are way off. All anti freeze does it lowers the freezing point of water, and inhibits water from corroding metal as quick. If you want to raise the boiling point of water you have to raise the pressure. Quote Link to comment Share on other sites More sharing options...
dave85 Posted January 31, 2005 Report Share Posted January 31, 2005 you are way off. All anti freeze does it lowers the freezing point of water, and inhibits water from corroding metal as quick. If you want to raise the boiling point of water you have to raise the pressure. ← Or put some impurities in it, like antifreeze :( Quote Link to comment Share on other sites More sharing options...
biketrialler Posted January 31, 2005 Report Share Posted January 31, 2005 Go find out, boil a jug full of normal water, then put some anti freeze in a fresh load and see when that boils eh! Quote Link to comment Share on other sites More sharing options...
Corish Posted January 31, 2005 Author Report Share Posted January 31, 2005 Go find out, boil a jug full of normal water, then put some anti freeze in a fresh load and see when that boils eh! ← Done it now, nice to pull, also I found out how to bleed by my self (Y) well easy! but it does pull gorgeous. works a bit shite though (Y) corish Quote Link to comment Share on other sites More sharing options...
