Caleb Posted January 30, 2005 Report Share Posted January 30, 2005 Hey everyone, i recently came to take my xtr brake lever off my bars and realised the bolt was rounded badly :D I thought maybe sawing throught the middle of the bolt would get it off the bars. If the blade would fit throught hat is, but then i wouldnt know how to get the other half out of the closed tapped section in the leve Any help would be appreciated, cheers Caleb Quote Link to comment Share on other sites More sharing options...
andrew69 Posted January 30, 2005 Report Share Posted January 30, 2005 (edited) can you glue an old 5mm in the bolt head? Andrew Edit or you can hammer a torks but in and undo it that way Edited January 30, 2005 by andrew69 Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted January 30, 2005 Report Share Posted January 30, 2005 Otherwise...drill a hole in it then you can do all sorts of things! Like...wedge an allen bit (from a ratchet set) into the hole...use a left handed tap (if you're lucky..) etc. adam Quote Link to comment Share on other sites More sharing options...
