Like Squeeky Brakes?
Mr Motivator
Turn up the volume.
V!Z pads..
I did the fingernail squeeze test, and they feel a tiny bit harder than my plaz pads. Similar to koxx pads I guess. Grips okish, like koxx, and are transparent :ermm: but most of all they have quite a high pitch squeek unlike most other pads on a grind.
Not bad for free I guess, perhaps could do with having more material on them.
Over and out, Sam
off to put my plazzies back in.
Edited by Sam@SouthTrials
Turn up the volume.
V!Z pads..
I did the fingernail squeeze test, and they feel a tiny bit harder than my plaz pads. Similar to koxx pads I guess. Grips okish, like koxx, and are transparent :P but most of all they have quite a high pitch squeek unlike most other pads on a grind.
Over and out, Sam
If you say there good....why are you putting your plazzies back on? :ermm:
Yeah they sound like they bite well and they do.. but when you lock the back brake and stamp on the forward pedal, they slip :P
Might just need bedding in some more though, and they should last quite a nice long time too :-
For the person that asked, they are 15quid new I belive.
Sam, I'm gonna keep using em for a bit longer. See what they are like on tomoro's ride :ermm:
