Magura Louise 02
aaroncosbey
HI guys, does anyone have any idea if i can lenghten the hose on my louise disc brake as it is too short.
Ive know you can use olives to shorten the hose and lengthen HS-33's.
the connection at the calliper looks like this.
can it be re used? and do i just have to buy more magura hose??
if you pop the hose off youll probly be able to see if its an olive (i would have thought so) and fix accordingly
I think the hose olive is at the top part (lever area) where the hose can be cut.
The problem is that i'm switching my brake to a bike that requires the hose to be longer (so that it fits on the handlebar).
At the bottom of the hose (the calliper part - in the pic above) the hose looks crimped and im not sure if i can reuse it?? or if i have to buy a new long hose......i'll phone magura in the morning!! :ermm:
