Quickly Need Help :)
*OnzaMike*
A little bit off topic, but if you cant change the colour of the text.....remove them completely...
Right click the icon and select [Rename]
Name the icon Alt+255 and hit Enter
( this means you hold down the Alt key and type 255 then release the Alt key )
The text will be gone from the icon.
For each successive icon to have the text eliminated, repeat the above sequence adding an additional Alt+255 sequence. For example, the second no text icon would be 'renamed' Alt+255 Alt+255, the third no text icon Alt+255 Alt+255 Alt+255, etc.
:blink:
:blink:
Dosnt work on mine, (xp home)
Yes it does.
But you need to make sure that num lock is on and that you are using the num pad at the right of the keyboard. And that you are using the left alt key.
If you still can't get your head around that, you can paste " " (What's between the marks).
