Alex.loves.boys Posted January 19, 2005 Report Share Posted January 19, 2005 (edited) hey i have a eno and i have a problem with my bike bu thats a differnt matter so anyway i need to get my freewheel off , now the normal freehweel remvoers do not fit it as only one of the slots go into it which dont give a good enoughgrip e.t.c to get it of soooo is there a specific tool for it. cheers alex :S Edited January 19, 2005 by mini MAN Quote Link to comment Share on other sites More sharing options...
JT! Posted January 19, 2005 Report Share Posted January 19, 2005 (edited) Well, the ACS tool does all freewheels....including dicats, (sort of but it still works). ACS is what i would call the standard freewheel, and thats the same as a eno. Thats what you need. Edited January 19, 2005 by JT! Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted January 19, 2005 Author Report Share Posted January 19, 2005 (edited) nope only one slot fit in the freehweel was bigger.e.g the slots where futher away and if the one you use fits obvioly it does where did u get it from Edited January 19, 2005 by mini MAN Quote Link to comment Share on other sites More sharing options...
JT! Posted January 19, 2005 Report Share Posted January 19, 2005 Well, my asc tool fits fine on my eno, i just got it from my LBS. :S Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted January 19, 2005 Author Report Share Posted January 19, 2005 Well, my asc tool fits fine on my eno, i just got it from my LBS. :S ← urm ok then shuld i try the one from superyccles? cheers alex Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 19, 2005 Report Share Posted January 19, 2005 its a standard fitting, get the acs tool above and it will work fine :S Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted January 19, 2005 Author Report Share Posted January 19, 2005 ok kool my mates didint fit at all nether dd my local bike shops :S Quote Link to comment Share on other sites More sharing options...
JT! Posted January 19, 2005 Report Share Posted January 19, 2005 Can you get a 16t tool and a 18t tool? Or are they all the same? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 19, 2005 Report Share Posted January 19, 2005 you can get a 13t tool which is a bit smaller Quote Link to comment Share on other sites More sharing options...
JT! Posted January 19, 2005 Report Share Posted January 19, 2005 you can get a 13t tool which is a bit smaller ← But 16 and 18 use the same tool? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 19, 2005 Report Share Posted January 19, 2005 yes, they use the same tool Quote Link to comment Share on other sites More sharing options...
JT! Posted January 19, 2005 Report Share Posted January 19, 2005 yes, they use the same tool ← Wonder why his isn't fitting then... :S Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted January 19, 2005 Report Share Posted January 19, 2005 They dont, well, my 18t tool didnt fit my mates 16tooth acs..... Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 19, 2005 Report Share Posted January 19, 2005 well i use my acs tool all the time at work and it fits........................ Quote Link to comment Share on other sites More sharing options...
JT! Posted January 20, 2005 Report Share Posted January 20, 2005 Its just one of those mysierys. Like when maguras only move from one side. Spooky :( Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 20, 2005 Report Share Posted January 20, 2005 Sticky piston syndrome isnt a mystery......Just take your pad off, pull on the piston gently with some pliers and spray some sort of lube like gt85, wd40 etc on the piston :( jobs a good`un :- Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted January 20, 2005 Report Share Posted January 20, 2005 I had this...but my tool was a cheap dicta one- i just bent the prongs inwards a bit with a hammer. Let's face it- why would you want to use to tool for any other freewheel? The eno is your baby now- make your tool fit it! adam Quote Link to comment Share on other sites More sharing options...
