will Posted January 16, 2005 Report Share Posted January 16, 2005 mySQL query error: UPDATE LOW_PRIORITY ibf_gallery_albums SET images=images+1, last_pic=5631, last_name='will', last_member_id=181 WHERE id=649 mySQL error: Unknown column 'last_member_id' in 'field list' mySQL error code: Date: Sunday 16th of January 2005 12:49:03 PM Anyone got any ideas as to why this might be happening when I try to uplaod an image to my gallery? Will. Quote Link to comment Share on other sites More sharing options...
Sam Nichols Posted January 16, 2005 Report Share Posted January 16, 2005 (edited) Same happens to me - its not you just a board problem sam Edited January 16, 2005 by nichols_sam Quote Link to comment Share on other sites More sharing options...
Danny Posted January 16, 2005 Report Share Posted January 16, 2005 Which skin are you using? All seams to be working fine here :o Was it uploading to your own personal gallery or one of the public ones? Found out this is a reported bug me thinks. Seams it only happens when you use upload image in the drop down box. If you view a gallery of yours and then click new image it works fine :o Ill try get it sorted ASAP Quote Link to comment Share on other sites More sharing options...
will Posted January 16, 2005 Author Report Share Posted January 16, 2005 (edited) AS far as I know im using the default skin, (light blue) Uploading to my gallery, EDIT: It seems to have worked originally. (Y) Thanks Will Edited January 16, 2005 by will Quote Link to comment Share on other sites More sharing options...
Sam Nichols Posted January 16, 2005 Report Share Posted January 16, 2005 Danny, It seems that it is actually uploading the images - just telling you that theres an SQL error etc etc. I found this earlier when i was trying to post images and i kept trying it - ended up with about 6 og the same pic! sam Quote Link to comment Share on other sites More sharing options...
