Frame Specs
Guest endofreak
Guest endofreak
I thought it might be quite useful to have a thread containing a few specs of some of the top trials frames.
List any frames that you may know the geometry and weights off.
Koxx Levelboss
Wheelbase - 1065mm
Chainstays - 385mm
Head angle - 71.4
Echo Pure
Wheelbase - 1060mm
Chainstays - 385mm
Head angle - 71.5
Echo Urban
Wheelbase - 1040mm
Chainstays - 385mm
Head angle - 73
Weight - 4.5lbs
Planet X Zebdi
Wheelbase - ?
Chainstays - 385mm
Head angle - 74
Top Tube - 21.5"
Weight - 4.5lbs
Guest Mr_DJ
Pashley 26 Mhz Trials:
Weight approx 4.5 lbs
14" seat tube
22" top tube
16" chainstays
73 mm BB shell
Tyre Clearance: 2.3" (although i can get a 2.35 kujo in there :-)
Guest prawn
id jsut liek to say that the echo urban is 4.6 and that the zebdi is only about 4.4lb or so because tehrs quite a difference betwent eh urban and the zebdi
zebdi tyre clearence-over 2.6 because my 2.5 has loads of room on a bmf rim
  • Like 1
  • 5 months later...
