mark-399 Posted September 16, 2004 Report Share Posted September 16, 2004 alot of people have been asking this so i thought id put this up p.s if you like your gearing more powerful the smaller cog on the back would be best and vice versa) front 22t use 17t,18t or 19t front 20t use 15t or 16t front 18t use 13t or 14t front 16t use 12t or 13t it may be best to try them all to see which best suits you Quote Link to comment Share on other sites More sharing options...
Phatmike Posted September 19, 2004 Report Share Posted September 19, 2004 22:17 = 1.294 22:18 = 1.222 22:19 = 1.158 20:15 = 1.333 20:16 = 1.25 20:17 = 1.764 18:13 = 1.385 18:14 = 1.286 16/12 = 1.333 16/13 = 1.231 16/14 = 1.143 So you can see what's closest to what. Quote Link to comment Share on other sites More sharing options...
JonMack Posted September 19, 2004 Report Share Posted September 19, 2004 Easier to read than Mikes. Quote Link to comment Share on other sites More sharing options...
Phatmike Posted September 19, 2004 Report Share Posted September 19, 2004 http://www.trials-shack.co.uk/fatmike/gears.xls Mwahaha. The solution to all of those annoying questions!! Quote Link to comment Share on other sites More sharing options...
Burton Posted July 11, 2005 Report Share Posted July 11, 2005 GEAR INCHES FORMULA: (Tire diameter in inches) x (Number of teeth in front chainring) ÷ (Number of teeth in rear sprocket). Useful for comparing Mod and Stock gear ratios. Its easy to see which uns are similar. Mod gear ratio 18:12 compare it to Stock 20:17 (20 x 18) ÷ 12 = 30 (26 x 20) ÷ 17 = 30.588 This shows that the stock gear ratio is stiffer than the mod un. (N) Tis a bit confussing :P but it does work Quote Link to comment Share on other sites More sharing options...
bquamb Posted July 28, 2005 Report Share Posted July 28, 2005 <img src='http://www.trials-forum.co.uk/gallery/1095181495/gallery_38_388_1095592185.jpg' border='0' alt='user posted image' /> Easier to read than Mikes. ← thanks guys... :( Quote Link to comment Share on other sites More sharing options...
