Duck Posted April 21, 2004 Report Share Posted April 21, 2004 Hi Does anyone know if a Koxx rim will fit my Echo ES2? Im running a Mavic 521 with a continental vertical at the moment and there is about 1.5cm room each side of the tyre. I've checked the FAQ's and theres nothing about it Thanks Phil Quote Link to comment Share on other sites More sharing options...
Janson Posted April 21, 2004 Report Share Posted April 21, 2004 Adjust the slave cylinders so that they're all the way backed out from the rim. Unscrew the TPA so the pads fully return. Remove wheel and measure the distance between the pads. If it's >47mm, you can fit one. Quote Link to comment Share on other sites More sharing options...
montybiketrial Posted April 21, 2004 Report Share Posted April 21, 2004 Think, he could be talking about fitting the tyre between the chainstays though :lol: Quote Link to comment Share on other sites More sharing options...
Mark W Posted April 25, 2004 Report Share Posted April 25, 2004 I've checked the FAQ's and theres nothing about it Hmm, that could be because it's not a FAQ? :(\ It should fit, because the Koxx is a wider rim and the tyre will have a squarer profile which should fit in nicely. I'd have thought... Quote Link to comment Share on other sites More sharing options...
