Johnty Posted March 4 Report Share Posted March 4 New to trials and bought a second-hand bike with Echo TR rim brakes on the rear wheel. Advert said they should work with a bleed so expected the worst but hoped for the best. Bled with Shimano fluid and both slaves are now leaking from somewhere around the piston. Definitely not from the hose connections. Is any maintenance that can be done to fix it? Looked around the board and elsewhere but couldn't find anything specific on this. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 4 Report Share Posted March 4 Sounds pretty standard for those Echo pistons. The only recommendation I'd give is to source some Magura slaves (or ideally a full brake) and swap them out Quote Link to comment Share on other sites More sharing options...
Johnty Posted March 5 Author Report Share Posted March 5 Thanks for the reply. That's the general idea I've got from reading around as well. Seems like the best option. Quote Link to comment Share on other sites More sharing options...
