Noyzex Posted January 17 Report Share Posted January 17 The rear rim of 26 is bent and rubbing on the brake pad, how can I resolve this? With a spoke key? Quote Link to comment Share on other sites More sharing options...
Noyzex Posted January 18 Author Report Share Posted January 18 The bike is completely new, I used it 2 times just to learn how to dribble on the rear wheel, now the rim tends to go to the left by pressing on the brake pad, the wheel feels braked, what could be causing this? Do you have any advice? A thousand thanks. Quote Link to comment Share on other sites More sharing options...
craigjames Posted January 18 Report Share Posted January 18 What bike is it? What rear wheel does it have? Quote Link to comment Share on other sites More sharing options...
Swoofty Posted January 18 Report Share Posted January 18 Make sure the wheel is still centered in the dropouts. Other than that the rim might need a little tune. Quote Link to comment Share on other sites More sharing options...
Noyzex Posted January 20 Author Report Share Posted January 20 (edited) On 18/01/2025 at 16:07, craigjames said: Che bici è? Che ruota posteriore ha? Crewkerz desire 26, Fit the Hashtag single wall 26 rims Edited January 20 by Noyzex Quote Link to comment Share on other sites More sharing options...
Noyzex Posted January 20 Author Report Share Posted January 20 How can I solve it? For now I have moved the brake outwards so as not to let the pad come into contact with the rim at the bent point, but how is it possible that it went wrong only with a few dribbles on the rear? How can I straighten the circle? Quote Link to comment Share on other sites More sharing options...
cwtrials Posted January 20 Report Share Posted January 20 Do you know how to true a wheel with a spoke key? Quote Link to comment Share on other sites More sharing options...
La Bourde Posted January 20 Report Share Posted January 20 First, check if the whole wheel is centered, I mean it is laced without an offset. Second, as Swoofty said, check first that the wheel is centered in the dropouts. This can only be the case with the oldest version of the Crewkerz Desire (the newest version has a 12mm through axle, so the wheel is centered). First question: Is this the newest Crewkerz Desire with a 12mm through axle or the previous one with the bolt-on rear wheel ? If the wheel js not centered in the dropouts or is laced with an offset, one brake pad will drag most of the time (if not not the whole time) against the rim. Second question: Does the pad drag against the rim for a short period? Then, the rim is untrue and you need to centered it by adjusting the spoke tension. I don't expect a wheel to get untrue after some hops on the rear wheel. But if you fell down on your bike, that could be the case. Quote Link to comment Share on other sites More sharing options...
Damon_Watson Posted 2 hours ago Report Share Posted 2 hours ago Spoke key if it’s maybe 20mm max hammer/adjustable/boulder smack it with the spokes loose to roughly straight then tighten again Quote Link to comment Share on other sites More sharing options...
