First grinding rim(light one)
Hi everyone,i am about to make my first grinding on my back rim,so i would like to make sure that everything would be good with the procedure.Here it's what i know about:
1.To use a brand new disk but what thickness?I would like light grind.
2.Metal cutting or stone one for?
3.Is better to have grinder with adjustable speed or not?If it has what speed have to be,slow or faster?
4.Do i need to clean with acetone after the grinding or does not have to?
And last question is:If i am using one brand pads after grinding and deciding to have different ones do i have to grind again or just clean surfaces with IPA or acetone?
Thank you for you time and answers.Every tips would be appreciated.
