signo97 Posted September 3, 2024 Report Share Posted September 3, 2024 Hello everyone, some people say that the hope aviation hose is worth it and some people say that it just add weight on your bike and that they can't tell the difference between this cable and the standard one with kevlar. Anyone had tried the difference? Thanks Quote Link to comment Share on other sites More sharing options...
Ali C Posted September 3, 2024 Report Share Posted September 3, 2024 Not worth it in my opinion, the internal bore size on the fittings is quite small which takes more effort to push fluid through, your brakes will feel like they’re bled with syrup if you use magura fluid and even if you use water it’ll never feel as good as standard hose 1 Quote Link to comment Share on other sites More sharing options...
Szymon Posted September 4, 2024 Report Share Posted September 4, 2024 I bought and installed such a cable from Ali to my Shigura. And the difference is noticeable. There's none of that final sponginess in the brake lever. EZMTB brake hose Quote Link to comment Share on other sites More sharing options...
La Bourde Posted September 4, 2024 Report Share Posted September 4, 2024 Do you want to use this hose with HS33 or with disc brakes? It makes no sense to use this type of hose in combination with HS33, because the system uses low pressure. This is not the case of disc brakes. According to my experience with Hope tech 3 brakes, the feeling of the rear brake was better than with the original one. It makes no difference regarding the front brake. But good hoses like goodridge shall be as good as hope aviation. 2 Quote Link to comment Share on other sites More sharing options...
signo97 Posted September 5, 2024 Author Report Share Posted September 5, 2024 Thank you guys, I think I will keep running the kevlar hose. I was tempted to put this aviation hose on my hope tech 3 brakes because I come from pure trials and I love brakes with a really aggressive bite. Quote Link to comment Share on other sites More sharing options...
