MaderaMark Posted June 9, 2024 Report Share Posted June 9, 2024 Quote Link to comment Share on other sites More sharing options...
Canardweb Posted June 9, 2024 Report Share Posted June 9, 2024 I would say yes but I have never owned TR levers myself. A few friends have and it's been nothing but disappointment. 2 Quote Link to comment Share on other sites More sharing options...
La Bourde Posted June 9, 2024 Report Share Posted June 9, 2024 (edited) These Magura HS11 are quite sensible to dirt: the dirt accumulates around the piston due to the shape of the lever. If you clean them regularly, that shall be fine. But the HS33 lever from 2005 is much better (after removing the edge) Edited June 9, 2024 by La Bourde 1 Quote Link to comment Share on other sites More sharing options...
MaderaMark Posted June 11, 2024 Author Report Share Posted June 11, 2024 On 6/9/2024 at 10:24 PM, La Bourde said: These Magura HS11 are quite sensible to dirt: the dirt accumulates around the piston due to the shape of the lever. If you clean them regularly, that shall be fine. But the HS33 lever from 2005 is much better (after removing the edge) my echo TR's lever started to act wierd, levers returns so slowly despite having new bleed and seals/o-rings. And the HS33 I saw online in my area were like gold. specially those with neon accents or the last HS33. These were the lowest price I have ever seen, that is why I ask if those were much better than echo.... Quote Link to comment Share on other sites More sharing options...
La Bourde Posted June 11, 2024 Report Share Posted June 11, 2024 The HS11 are really cheap... It is plastic...sorry, carbotecture 😁 and every part on the brake is built to cost as less as possible. Thus it is difficult to repair. For example the axle of the lever blade is just a pin maintain by interference fitting in the plastic body... 1 1 Quote Link to comment Share on other sites More sharing options...
basstrials Posted June 12, 2024 Report Share Posted June 12, 2024 Maybe Shimaecho? Quote Link to comment Share on other sites More sharing options...
Canardweb Posted June 12, 2024 Report Share Posted June 12, 2024 19 hours ago, La Bourde said: The HS11 are really cheap... It is plastic...sorry, carbotecture 😁 and every part on the brake is built to cost as less as possible. Thus it is difficult to repair. For example the axle of the lever blade is just a pin maintain by interference fitting in the plastic body... Sad but true Quote Link to comment Share on other sites More sharing options...
Akiragi Posted June 14, 2024 Report Share Posted June 14, 2024 yes Quote Link to comment Share on other sites More sharing options...
The dab Posted June 18, 2024 Report Share Posted June 18, 2024 Has the master piston expanded over time? Could be to do with the issue of slow lever? Quote Link to comment Share on other sites More sharing options...
