La Bourde Posted October 17, 2023 Report Share Posted October 17, 2023 Hi, Recently I bought a new HS33 brake that came with Echo calipers. I never used this brake, I was just looking for some lever spare parts. I have to bleed a rear brake and I was thinking, that I can replace the Magura calipers with these Echo calipers. Are the Echo calipers better than the Magura original ones? Or do you recommend the Magura's ones? Thanks for you recommendations. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted October 18, 2023 Report Share Posted October 18, 2023 Echo's calipers are shorter to reduce the clutter at the cranks' ends. I would recommend Magura's as they are in my experience flawless. Never had experience with Echo's so can't really tell... Quote Link to comment Share on other sites More sharing options...
Target Posted October 18, 2023 Report Share Posted October 18, 2023 Echo calipers are more compact than Magura, so the chances to get into situation when your cranks are rubbing the calipers are lower. Echo calipers are also a bit lighter. The only downside is a reliability. All Echo calipers I've used lasted for about a year or two. Then they either started to leak, or the cylinders were getting stuck and had troubles with returning to initial position. Personally, I prefer Echo calipers because of their compactness and weight. But I totally get why some people hate them, Magura calipers seem to last longer. Anyway, both calipers are fine, you will hardly notice any difference. Quote Link to comment Share on other sites More sharing options...
La Bourde Posted October 18, 2023 Author Report Share Posted October 18, 2023 Thanks guys. Reliability is really important to me. I think, I will stick to magura. Quote Link to comment Share on other sites More sharing options...
Szymon Posted October 20, 2023 Report Share Posted October 20, 2023 I had an Echo and they started leaking. No problems with Magura. Echo are actually lighter and shorter. Quote Link to comment Share on other sites More sharing options...
Chakers1998 Posted October 21, 2023 Report Share Posted October 21, 2023 I've had both leak, but Echo were by far the worst. Great for crank clearance though. Quote Link to comment Share on other sites More sharing options...
La Bourde Posted October 21, 2023 Author Report Share Posted October 21, 2023 Did you bleed them with maguras oil or something else? Quote Link to comment Share on other sites More sharing options...
