Szymon Posted October 2, 2023 Report Share Posted October 2, 2023 I see more and more people riding on Maxxis Rekon 24x2.20 tyres. Can any user comment on them? Compare it to Holy Roller? Quote Link to comment Share on other sites More sharing options...
ben_travis Posted October 2, 2023 Report Share Posted October 2, 2023 Light weight, and with a little modification, even lighter. Definitely helps with moves where the bike spins (FJWs, whips, spins etc) Tread pattern isn't too restricting for street riding Works tubeless Sidewalls are very thin, and really require to use higher pressures (i.e. 45psi +) unless you like changing inner tubes (or in my experience, buying a new tyre, because you tore the sidewall) Narrow profile isn't as reassuring as 2.4" in my experience 1 Quote Link to comment Share on other sites More sharing options...
Szymon Posted October 3, 2023 Author Report Share Posted October 3, 2023 How about grip? Especially when it's cold or wet? With Holy Roller and tubolito I run at 45PSI pressure all the time. Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted October 3, 2023 Report Share Posted October 3, 2023 45 minutes ago, Szymon said: How about grip? Especially when it's cold or wet? With Holy Roller and tubolito I run at 45PSI pressure all the time. Maxxis are great for informing everyone what that particular type of tyres grip is, what does it say on the sidewall? Used to be Maxx Pro, Super Tacky and Slow Reezay. Now I think its Maxx Terra and Maxx Grip. What type of wet surface are you asking about? Porous rock, marble, grass, tarmac, concrete, bla de bla de bla... 1 Quote Link to comment Share on other sites More sharing options...
Szymon Posted October 3, 2023 Author Report Share Posted October 3, 2023 20 minutes ago, Ross McArthur said: Maxxis are great for informing everyone what that particular type of tyres grip is, what does it say on the sidewall? Used to be Maxx Pro, Super Tacky and Slow Reezay. Now I think its Maxx Terra and Maxx Grip. What type of wet surface are you asking about? Porous rock, marble, grass, tarmac, concrete, bla de bla de bla... Dual Compound. Wet tarmac and concrete. Quote Link to comment Share on other sites More sharing options...
Daan Posted October 3, 2023 Report Share Posted October 3, 2023 Probably not great, at least the dual compound crossmark were a bit ass on wet concrete and brick. Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted November 23, 2023 Report Share Posted November 23, 2023 Are those Tubolito tubes any good? Quote Link to comment Share on other sites More sharing options...
Szymon Posted November 23, 2023 Author Report Share Posted November 23, 2023 No problems with tubolito. I use the BMX version with a copper valve. Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted November 23, 2023 Report Share Posted November 23, 2023 41 minutes ago, Szymon said: No problems with tubolito. I use the BMX version with a copper valve. The weight saving sounds good but not sure if I can justify the cost, £28 for the 24" version or £5.50 for the Continental 24" tube I currently run. Quote Link to comment Share on other sites More sharing options...
Szymon Posted November 23, 2023 Author Report Share Posted November 23, 2023 Two tubolito tubes save 250g. 250g for £50 is not a high price I think. Quote Link to comment Share on other sites More sharing options...
La Bourde Posted November 23, 2023 Report Share Posted November 23, 2023 (edited) There is the unspoken rule of 1g = 1 USD (or €).😁 I heard from a pro rider he had troubles with turbolito by really cold weather (around 0°C, 32°F). If I recall correctly, he said they get less malleable and he got punctures. Edited November 23, 2023 by La Bourde Quote Link to comment Share on other sites More sharing options...
Swoofty Posted November 23, 2023 Report Share Posted November 23, 2023 I've used tubolito only in the front, but never had a problem. Only one flat from a gnarly piece of glass. Here in the States I've had no luck finding the schrader version of the tubos and I really dislike presta valves. It also doesn't get cold here in Los Angeles so can't comment on that. Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 24, 2023 Report Share Posted November 24, 2023 My turbolito tube lasted 20 mins the valve randomly snapped…maybe there was some twisting forces going on or something…if they do a metal one then that’s what I’d go for Quote Link to comment Share on other sites More sharing options...
Canardweb Posted November 25, 2023 Report Share Posted November 25, 2023 14 hours ago, Ali C said: My turbolito tube lasted 20 mins the valve randomly snapped…maybe there was some twisting forces going on or something…if they do a metal one then that’s what I’d go for One of my spanish friends had exactly the same when he tried them! Quote Link to comment Share on other sites More sharing options...
Szymon Posted November 27, 2023 Author Report Share Posted November 27, 2023 Quote Link to comment Share on other sites More sharing options...
Szymon Posted December 11, 2023 Author Report Share Posted December 11, 2023 Tires purchased and installed. So far, three rides in poor conditions. And I am very satisfied. Wet grip seems to be better than the Holy Roller. Weight 595g and 614g. They are thinner than Holy Roller but it doesn't bother me yet. I'm waiting for dry conditions. 1 Quote Link to comment Share on other sites More sharing options...
Swoofty Posted February 4, 2024 Report Share Posted February 4, 2024 Any dry conditions yet? How are they holding up? Quote Link to comment Share on other sites More sharing options...
