Szymon Posted February 12, 2023 Report Share Posted February 12, 2023 Hi, Does anyone know the spokes length on the Inspired Pro 24" and Inspired Team 24" wheels? Quote Link to comment Share on other sites More sharing options...
Mark W Posted February 13, 2023 Report Share Posted February 13, 2023 For the Pro wheel, assuming it's the Inspired Sealed Rear Disc hub to the Inspired Pro V2 rim, it's 234mm non-drive/236mm drive side. For the Team wheel, if it's a Hope to the Team V2 (up to 2020) rim it's 230mm both sides. If it's the 2020-onwards one (so the updated, tubeless-friendly rim design) then it's 228mm both sides. 2 Quote Link to comment Share on other sites More sharing options...
Szymon Posted February 14, 2023 Author Report Share Posted February 14, 2023 Thanks a lot! Do you know what it looks like for the front Pro wheel? Quote Link to comment Share on other sites More sharing options...
Mark W Posted February 14, 2023 Report Share Posted February 14, 2023 49 minutes ago, Szymon said: Do you know what it looks like for the front Pro wheel? From new, they're 233mm/236mm. In all honesty I'm not sure whether they're closer to 232mm or 234mm if you're stuck with even length spokes, sorry! The front hub dimensions are available here, and the ERD of the rim is 488mm, so you could always enter them into the online spoke calculator of your choice if you wanted to double check. 1 Quote Link to comment Share on other sites More sharing options...
