Chakers1998 Posted December 7, 2022 Report Share Posted December 7, 2022 Has anyone snapped one of these BBs or heard of anyone snapping one? Or has anyone snapped a Ti Isis BB of another manufacturer? Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 8, 2022 Report Share Posted December 8, 2022 I've seen some snapped Echo Ti BBs. Don't seem to recall seeing any snapped Trialtech or Reset BBs, but I'm sure someone will have done no doubt. The Trialtech ones should be pretty tough though, they're M14 rather than M15 so there's a bit more material in the axle. 1 Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted December 8, 2022 Report Share Posted December 8, 2022 Yep, at least 2 Ti echo bb axles. 1 Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 9, 2022 Report Share Posted December 9, 2022 10 hours ago, Ross McArthur said: Yep, at least 2 Ti echo bb axles. Aye, the super long crank bolts finishing pretty much exactly where the crank splines did led to a stress riser. Shorter bolts help a lot. Never seen a failed axle on the Trialtech one, mainly because of the M14 thread, but also because of excellent quality and correctly sized crank bolts. 2 Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted December 9, 2022 Report Share Posted December 9, 2022 7 hours ago, AdamR28 said: Aye, the super long crank bolts finishing pretty much exactly where the crank splines did led to a stress riser. Shorter bolts help a lot. Never seen a failed axle on the Trialtech one, mainly because of the M14 thread, but also because of excellent quality and correctly sized crank bolts. Ahh! Good to know. I’ve got a good Ti bb axle sitting waiting to be fitted and I was holding back. The good thing about the longer alloy echo bolts was they’re light. x2 shorter steel bolts might negate the weight saving using the Ti bb haha. 1 Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 9, 2022 Report Share Posted December 9, 2022 Monty or (fairly sure) Jitsie ones will work nicely. Or lop a bit off the Echo ones! Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted December 9, 2022 Report Share Posted December 9, 2022 Did contemplate that! Now you’ve said it, it’ll need to be done. Quote Link to comment Share on other sites More sharing options...
Target Posted December 11, 2022 Report Share Posted December 11, 2022 Speaking of bolts, there are some titanium M15 bolts that due to minimalistic design are actually lighter than aluminium Echo ones. They are short and have 10 mm hex socket. Have been using them for seven years with Echo ti BB. 1 Quote Link to comment Share on other sites More sharing options...
