cut tyres over and over
signo97
Hi, i actually ride an inspired hex with tubeless and cushcore inserts and i’m trying all the tyres available on the market but i keep cut tyres after one or two months of use. I usually keep 40 psi or a little bit less. I loved my maxxis ikon tan wall but i just ruined them same for continental with shieldwall, now i’m using normal maxxis ikon without tan walls hope that this made differences. my last try will be with a continental der kaiser without ribs. Someone had the same problem? thanks
ripping on the sidewall?
I stopped using Cushcore after my Conti tyre got cut on the sidewall. I feel the Cushcore pushed on the sidewall too much and either weakened them or made them more pronounced and more likely to make contact with objects. Since switching to a Rimpact insert I haven't had any issues
