Just got a Da Bomb Harbinger, need help with chain tensioner please
GNARLY
so i'm new to trials, wanted something cheap and managed to get a Harbinger, like new, chains a tad lose on the bottom and hits the frame, without checking i ordered some SE racing chain tensioners which fit a 10mm axle, just went to check and my axle is huge, bigger then 10mm, any ideas on what i can do? thanks :)
If the axle is huge, it's going to be 14mm, which is the standard for BMX wheels.
Well you can either drill yours out to 14mm, or try and get to a bmx shop and pick some 14mm ones up. If you go to the shop in person you can always bring the wheel nut so you can compare the sizes.
Return the 10mm ones, or keep them for another bike maybe
My ridding buddy had one of those long before I was into trials. Does it happen to be orange? It was the first trials bike I ever rode.
