DJEHB Posted March 27, 2022 Report Share Posted March 27, 2022 Hi TF. Wondering if anyone can help with this puzzle… My i9 hydras are currently the following configuration: - Rear, 135 bolt in - Front, 110 15mm through axle I want to run them on my new frame and fork which has the following configuration: - Rear, 135 12mm through axle - Front 110 20mm through axle Hoping someone know what axle / end caps I need to order! To add to the complexity I have Pro 4s in the correct config, unsure if I can steal the end caps / axles from them?! Quote Link to comment Share on other sites More sharing options...
DJEHB Posted March 27, 2022 Author Report Share Posted March 27, 2022 @AdamR28I’m just going to tag you in this immediately Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 27, 2022 Report Share Posted March 27, 2022 You can use / steal the end caps from the Hope front hub. Rear is more tricky... ideally would be new I9 end caps and axle, but it might be possible to convert what you have with the help of a lathe... I'm away for a few days but pop me an email at Tarty and will check when back 1 Quote Link to comment Share on other sites More sharing options...
Swoofty Posted March 28, 2022 Report Share Posted March 28, 2022 If you pose the same question on I9s website (service@industrynine.com) they'll get back to you quickly as well and usually with a link to the product page. 1 Quote Link to comment Share on other sites More sharing options...
DJEHB Posted March 28, 2022 Author Report Share Posted March 28, 2022 (edited) Thank you both. Adam - I’ll try source the axle + end caps first but will reach out if no luck. Edit - All sorted. New axle + end caps on the way for both rear hubs. Cheers guys Edited March 28, 2022 by DJEHB Quote Link to comment Share on other sites More sharing options...
