Swoofty Posted December 20, 2021 Report Share Posted December 20, 2021 Has anyone else broken one of these while riding? It wasn't over-tightened when installed and it must have snapped recently as it was barely holding on when I noticed it was askew in the crank today. I've ordered a replacement, but I wonder if it will just happen again. My screw finder doesn't go up to M18 (i think it's an M18 anyway). Does anybody know what size bolt and thread pitch would make a steel/ti replacement for it? Quote Link to comment Share on other sites More sharing options...
aener Posted December 21, 2021 Report Share Posted December 21, 2021 Pretty sure I remember being amused seeing someone running a Trialtech Threaded Top Cap in there, which would make it an 18x1mm thread. 1 Quote Link to comment Share on other sites More sharing options...
Cap Posted December 22, 2021 Report Share Posted December 22, 2021 The preload bolt should only really be under very slight pressure, I would check the crank pinch bolts are torqued up correctly as they are what should stop the crank from coming off. With that being said as aener pointed out a trialtech top cap bolt is the same thread and has a lot more material. I believe it is M18 x 1.0 thread. Quote Link to comment Share on other sites More sharing options...
Swoofty Posted December 22, 2021 Author Report Share Posted December 22, 2021 Thanks guys! After seeing how thin the connection is now that it's broken, I think I might upgrade to the TT. It lasted a year at least. Quote Link to comment Share on other sites More sharing options...
Swoofty Posted December 23, 2021 Author Report Share Posted December 23, 2021 Apparently I've been living under a rock. A simple google search revealed that there are tons of M18 crank bolts out there; in every material imaginable. I guess it was figuring out that it was an M18 was the real trick. Thanks again guys! 1 Quote Link to comment Share on other sites More sharing options...
