Rip Posted October 2, 2021 Report Share Posted October 2, 2021 Anyone know what size packer I need to use between the pistons in order to get them to poke out enough for lubing and cleaning (with pads removed) but not too far that they pop out and cause me all manor of bad times? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 2, 2021 Report Share Posted October 2, 2021 About the same as a pair of pads. Quote Link to comment Share on other sites More sharing options...
Rip Posted October 2, 2021 Author Report Share Posted October 2, 2021 38 minutes ago, Adam@TartyBikes said: About the same as a pair of pads. Thanks, that actually makes a lot of sense thinking about it lol Quote Link to comment Share on other sites More sharing options...
Swoofty Posted October 31, 2021 Report Share Posted October 31, 2021 What do you lube them with? WD40, Bosheild, freehub oil? I find myself in need of this sort of maintenance all of a sudden. Quote Link to comment Share on other sites More sharing options...
Rip Posted October 31, 2021 Author Report Share Posted October 31, 2021 1 hour ago, Swoofty said: What do you lube them with? WD40, Bosheild, freehub oil? I find myself in need of this sort of maintenance all of a sudden. I was told to use whatever brake fluid your brakes use so I used a bit of Royal Blood. to be honest though it didn't make much difference, I was hoping the pads would return a bit more and give me a little more pad clearance. MT7s are known for little/no pad clearance so I guess that's my problem. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 31, 2021 Report Share Posted October 31, 2021 Hope / Hunter silicone lube works great. 1 Quote Link to comment Share on other sites More sharing options...
Swoofty Posted October 31, 2021 Report Share Posted October 31, 2021 10 hours ago, Rip said: I was told to use whatever brake fluid your brakes use so I used a bit of Royal Blood. to be honest though it didn't make much difference, I was hoping the pads would return a bit more and give me a little more pad clearance. MT7s are known for little/no pad clearance so I guess that's my problem. That's also what I found from other forums. I'm also dealing with pad clearance, but on MT5s. I've got a TMS fork with poorly aligned post mounts that won't allow the caliper to slide far enough over to center the rotor. No matter what I do the rotor just howls when I ride. Quote Link to comment Share on other sites More sharing options...
Rip Posted October 31, 2021 Author Report Share Posted October 31, 2021 (edited) Mine isn't that bad luckily but sometimes when I'm just sat on the bike chilling some small movements cause the brakes to squeak and whine a bit and it annoys me. No amount of caliper alignment fixes it so it must be the pads are not returning, maybe I'll see if I can bodge together some return springs for them. Edited October 31, 2021 by Rip Quote Link to comment Share on other sites More sharing options...
Rip Posted November 1, 2021 Author Report Share Posted November 1, 2021 On 31/10/2021 at 8:06 AM, Adam@TartyBikes said: Hope / Hunter silicone lube works great. I might give that a go then. Quote Link to comment Share on other sites More sharing options...
