smiddy86 Posted July 19, 2021 Report Share Posted July 19, 2021 just wondering what stem would be best for a streety setup.on a zebdi Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted July 19, 2021 Report Share Posted July 19, 2021 Something like a 90/100 by 10/15 with a 2" rise bar with a 10mm spacer under the stem. Depends what you want the bike to ride like, how tall you are and what length fork you run. Quote Link to comment Share on other sites More sharing options...
smiddy86 Posted July 19, 2021 Author Report Share Posted July 19, 2021 (edited) Want it for riding streety style riding .I'm 5 foot 7 and the bikes running onza tuff guy forks Edited July 19, 2021 by smiddy86 Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted July 19, 2021 Report Share Posted July 19, 2021 Another way of doing it would be to look at what you’re running now, ask yourself does it feel cramped or too roomy, i.e a dog on the back wheel or too hard to pull up to manual? Then go from there. Generally though, whatever you run, the more you ride the more you’ll get used to it, so get out there and give it some beans. Quote Link to comment Share on other sites More sharing options...
smiddy86 Posted July 20, 2021 Author Report Share Posted July 20, 2021 (edited) Its nice on the backwheel but feels a bit hard to pull up to manual and bunnyhop Edited July 20, 2021 by smiddy86 Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted July 20, 2021 Report Share Posted July 20, 2021 Post a photo of your set up so we can see what we are dealing with, hombre. Quote Link to comment Share on other sites More sharing options...
smiddy86 Posted July 20, 2021 Author Report Share Posted July 20, 2021 1 Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 20, 2021 Report Share Posted July 20, 2021 Are the tuf guys steel? Quote Link to comment Share on other sites More sharing options...
smiddy86 Posted July 20, 2021 Author Report Share Posted July 20, 2021 Yes Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted July 21, 2021 Report Share Posted July 21, 2021 Looks like a fine set up. Try the 10mm under the stem. If you then find its more of a dog on the back wheel, swap the 10 for 2 5mm's and play around with the height.. Bars look "back" enough. Only other advice is practise. 1 Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 21, 2021 Report Share Posted July 21, 2021 21 hours ago, smiddy86 said: Its nice on the backwheel but feels a bit hard to pull up to manual and bunnyhop Worth noting that those two are generally a trade-off. For trials stuff you typically want to have your weight centred further forward on the bike, but for streety stuff you want it further back. Usually one side has to suffer a little for the other, so it's probably going to boil down to what you want the bike to be better at. If you want it streety, a shorter/higher setup will work best but that will compromise the trialsy-ness of it. Longer/lower will be better for trialsy stuff, but it'll make streety stuff harder. As Ross says, practise and getting used to the technique required for the bike will help most in the long run, but playing with bar roll and stacker height can dial things in. 1 Quote Link to comment Share on other sites More sharing options...
