Jamie mcdonald Posted July 7, 2021 Report Share Posted July 7, 2021 I recently have bought a sram dub cranks set With the inspired bash. I had a bike shop instal it and it turns out they have not put any spacers in.Allowing it to shift backs and forth.Sram recommends a 4.5mm spacers for my frame size But the bb only came with a 2.5mm spacer and if I were to install that it would remove play but the preloader will be pretty far out. I just dont know If it would work well and not damage my new cranks and bb. Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 8, 2021 Report Share Posted July 8, 2021 That wouldn't really be ideal. That's why the SRAM cranksets sold with those bashrings come with this spacer: That fits within the bashring constraints and spaces it out correctly. You could get away with doing it by filing/grinding/whatevering a regular 4.5mm spacer but it'll probably take some doing. It'll be better than running your cranks incorrectly spaced though. Quote Link to comment Share on other sites More sharing options...
Jamie mcdonald Posted July 8, 2021 Author Report Share Posted July 8, 2021 2 minutes ago, Mark W said: That wouldn't really be ideal. That's why the SRAM cranksets sold with those bashrings come with this spacer: That fits within the bashring constraints and spaces it out correctly. You could get away with doing it by filing/grinding/whatevering a regular 4.5mm spacer but it'll probably take some doing. It'll be better than running your cranks incorrectly spaced though. Ok thanks Quote Link to comment Share on other sites More sharing options...
