+30 BB on a street trials bike!?! TMS Urbex
Swoofty
Say it ain't so! Are street trials bikes going the way of pure now? +30 BB on a street bike sounds crazy, but I haven't ridden one yet. The rest of the geo is fairly standard, 985 wheelbase, 74 deg headangle. It's got that same 'between the stays' rear brake mount as the TMS Champgn too. It also comes in white apparently. If anybody rides one, let me know what it's like.
The original Fourplay was +35mm...
I prefer a slightly higher BB, the +25mm on the Arcade was as low as I wanted to go. Any lower just feels too 'stable' somehow. I prefer a bike with a bit of inherent instability because that way when you harness that it makes the bike more agile, rather than having a really stable bike that you have to wrestle more. When I first went to the 'new' Fourplay after the original Mk1, I hated it at first because the big drop in BB height made it feel hard to do a lot of things on. Things like manual 180s in particular - it felt like my feet were so low/into the bike that it was hard to get the carve and preload on the go.
It's always seemed to me that the 'you need a really low BB for street' came from the way everyone used to use old MTB frames for street bikes, rather than it necessarily being the best for the intended purpose.
  • Like 2
Expand
I had no idea the original 4play was that high. How long ago was that? (I've only been here 12 years) What was the biggest factor in changing it lower? I guess there really isn't a hard and fast definition for a street trials bike anyway. I'd say the Alias is a street trials bike, but it's way high BB and no seat so kind of a category unto itself. I'm happiest with +25 right now, but the wheelbase and head angle play a big part too.
I've always thought people were way too obsessed with BB rise. Yes, it makes a difference, but it's not like it's the defining factor of a bike and what you can do on it. Especially when it's quite a middling amount.
If it's too high, you can counter it with a higher bar/stem. Too low, and lower the bar and stem. Up to a point, obviously. It does make a difference - but small changes from what you are used to don't make as much as people seem to think.
They also feel different between the bikes because of the radius of the wheels putting you different heights from the ground. +65 on a mod feels much less outlandish than +65 on a stock.
Certainly, some people can, but I'd be very surprised if more than 5% of riders can legitimately feel the difference between +25 and +30, once you'd added/removed a 5mm stem stacker accordingly. I certainly couldn't.
And those people that ARE so hyper sensitive to feeling the difference, I don't think it would make much difference in how they can ride after one or two to adjust.
I'd liken geometry obsession with mixing audio. Knowing the frequencies (aka geo measurements) can help guide you to the right area, but to make the difference you actually want you need to listen (aka ride) and see if it's right. If your kick is too boomy (manuals are unstable) it's much better to stick a peak/trough on the EQ and sweep the frequencies rather than just assuming you need to cut 125Hz because that's the theoretically correct response. Sometimes it's an underlying fundamental, or a resonance with the bass. Don't mix by numbers, because it's your ears that are going to listen to it.
5mm in the BB is only the same as switching from modern thin pedals back to something like the old shape of V12. They're thick enough that they'd put you that bit higher off the ground. Does that make it not a street bike any more? :lol: This isn't meant to read as a rant - just trying to make my point.
  • Like 1
I remember getting my 2011 Fourplay and it felt really low compared to the mk1. Could be making it up but I'm sure they lifted it again when they re-jigged the geo for the 2012 revision?
Given the choice I much preferred the higher BB on the mk1 hence why I was after that or a zoot last year (and ended up with the Adamant)
Expand
That was the Fourplay from the original one in 2007-ish through to the change in frame design in 2011. They made the chainstays shorter and lowered the BB, as well as tweaking the front reach measurement. It was just to make it a bit more contemporary, for want of a better word. I think the original Fourplay was almost a translation of the geometry of the 26" street-orientated trials bikes people were riding at the time, with the 2011 and onward versions taking what they learned from that to then improve it for a 24" wheel.
Expand
I really didn't get on with the first 2011 Fourplay I had for the reasons I mentioned above. I think us riding in different ways may make more of a difference on that though - if you're pedalling into a lot of stuff it doesn't make as much difference, but if you're not pedalling into things it does as I think the underlying 'feel'/'handling' of the bike is more noticeable then. Using the manny 180 reference I made above, doing them on the 2011 Fourplay before I modded the geo wasn't great. As before, it just felt like my feet were too low through the bike, and it was really hard to get it to turn and do what I wanted it to do. It's hard to explain, but when you could feel the balance point and the way you had to carve it, it felt like the lower BB was stopping that from happening as it basically just wanted to go in a straight line more. If I'd been cranking the 180 it wouldn't really have been a problem as the carve and pop parts are so different to non-cranked ones. That was around the time I was transitioning from pedalling into spins and hops up stuff into bunnyhopping everything so I guess that may have highlighted it more, but it's also something I notice whenever I've had a go on a Fourplay or Skye. That geo works for some people, but definitely not for me.
Changing bar and stem for a lower BB doesn't really do much to change the underlying characteristic of the bike as such, in much the same way that a higher bar/stem on a high BB bike doesn't stop it from feeling like a high BB bike - it just mitigates the change in body position a little. It's not really the body position on the bike that's the problem for me with low BBs, and if anything dropping bar height would have made it even worse.
It's definitely not the defining characteristic of a bike though, so I do fully agree with you on that bit. Much like how people used to judge bikes solely on WB, it all needs to be taken into consideration.
Expand
Correct (Y)
Original Fourplay - CS: 385mm, BB: +35mm
2011 Fourplay - CS: 380mm, BB: +20mm
2012 Fourplay - CS: 375mm, BB: +25mm
  • Like 1
  • 1 year later...
Ok, I'm an idiot. I bought one of these things. It spent 3 weeks in customs for no apparent reason and it's taken me all weekend to set it up properly (I got it as a frame & fork). This is my 3rd TMS now (Evo6, Silex 3 and now Urbex) and they've all had 'issues' straight out of the box. I'm trying not to pass judgement too soon, but the frustration to fun ratio is the wrong way around at the moment. Maybe next weekend I'll be raving about how awesome this bike is...
  • Like 1
Frustration or not, it does look spiffy. Throw it out though, what frustrated you most? On my Silex it was the stupid hose guide on the fork. Filed it off eventually. And a lot of bolts included for the rear wheel chain tugs, but none long enough to run it in the only position you'd want to run it in. But hey, at least the whole thing was welded together straigher than my Hex, both fork and rear end.
I do see you don't want to run any Hope or straight connected brake with the way it's mounted back there haha. How many of these bikes do you have now? 😁
Expand
Looks good too me, especially with the fat HolyRoller and high profile carbon wheels!
What issues did you encountered?
Compatibility of parts? Or just bad production?
Expand
I cracked left dropout on the TMS Silex V2 from the second sidehop. What do you know about frustration? xD
All right. You want the dirt, here we go. Every, yes EVERY, TMS fork I've had has had issues. This one is no exception, well, actually, maybe just the through axle this time. The disc mount was faced pretty square which was nice, but the through axle was too long. Yes. Too long. When you fully tighten the axle it measures to about 103mm. WTF?!? This was not what I thought was the problem initially so I was messing with the preload on my hub etc when I realized it was the friggin through axle! I didn't have any 15mm washers on hand so I rigged about 4 washers that were close to compensate for the too long axle. Now I've ordered an axle that will be correct (not from TMS) but it won't be here until next week.
Next up is there novel rear disc mount. I must admit that this is one of the reasons I bought this frame because I just wanted to see what that mount's all about. I'm over it already. I wanted the older TMS Champgn that had this mount, but they were all gone by the time I had enough money to buy one. The Urbex has basically the same geo as my Guilty so this purchase is pretty superfluous, but curiosity is what it is. The 'between the stays' brake mount is dumb. I'm totally fine with 180 rotors, but yeah, good luck putting a +20 or +40 adapter in there. You can't use an extension to tighten the brake bolt and I couldn't even get my 1/4" mini ratchet in there so you're forced to use a regular 5mm allen with about 25 deg to play with. Imagine how much fun it was to set up an MT5 like this. Oh, and the rear brake mount needed to be faced. Can anyone guess how easy it was to get the facing tool in there? I should have turned it into a drinking game; that would have been more fun. All the while my Guilty is just laughing in the background.
I just notice that the white and the black frame differ ... The black one has a rear through axle!
My gosh! I don't get it. If they want to produce two different frames, to split entry level and high end level, why do the entry level frame use hydroformed multi-butted tubes and CNC parts but a 5mm axle? How much cost they save this way?
Crewkerz had it right with the old Freed/Desire and their tubes with simple shapes, no hydroforming and no CNC or forged parts (but the rear ends). The Jealousy is much more expensive to produce.
Did you contact TMS regarding the axle? That is quite annoying!
Edited by La Bourde
That's not really anything new for TMS. The Silex frames used to have different head tubes and headset types depending on the frame colour you bought. With that one I think it was just delivery timing of different batches coinciding, so the standard head tube frames were 'old' and the integrated head tube frames were 'new', but they were delivered at the same time. It may be a similar story here, but it could be they decided to do an equivalent of Inspired's Pro vs. Team frame kit specs, just with no real mention or explanation of it anywhere.
Yeah I knew the white and black frames were different and I would have preferred the through axle, but I didn't want to repaint the frame. I've broken a rear through axle, but I've never broken a bolt on hub. Either way it's the fixed rear wheel that matters most. No more sliding dropouts for me.
Well it put a big smile on my face today. Not 100% sorted, but today's ride was pretty great. The brakes are bedded now and everything is properly tight. First thing I noticed was this 'dampening' effect the frame has. It feels more like steel than alu. I guess all those 'bowed' stays don't transmit feedback directly to the cranks or stem. That feeling might not be for everyone, but my old body got used to it pretty quickly. With a 90x35 it's also not as tall as any of my other bikes. I've already ordered a 90x45 to remedy that. I put it on the scale after my ride and was devastated to find it's a full pound heavier than my Guilty! It comes in at 20.8#/9.4kg. Nothing really to do to change that either as they're basically the same spec. I guess used Holy Rollers are lighter than new Holy Rollers 😉 If I'm not too sore tomorrow it'll get another full send.
Edited by Swoofty
  • Like 4
