Richie612 Posted April 16, 2021 Report Share Posted April 16, 2021 Hello guys I've got terrible calluses on both hands since starting trials. I'm sure a few of you guys have had the same issue too. What did you do to solve this? Are foam grips a better option? I currently use the standard grips which came on my Fourplay which are the Lizard Skinz. Rich Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 16, 2021 Report Share Posted April 16, 2021 Foam grips are amazing, otherwise I'd recommend a corn razor (can get from chemists) and pumice stone. My hands are constantly sore and getting hammered from pullup bars and that's what I use. Quote Link to comment Share on other sites More sharing options...
marg26 Posted April 16, 2021 Report Share Posted April 16, 2021 (edited) Quarter a sheet of medium/fine grit paper, wrap it around a pencil, and sand the excess down. Wear gloves when the callouses are worst. I always get them worse on my left hand too, the right hand they don't seem to get too bad, I'm right handed. Edited April 16, 2021 by marg26 Quote Link to comment Share on other sites More sharing options...
bikeperson45 Posted April 16, 2021 Report Share Posted April 16, 2021 37 minutes ago, marg26 said: I always get them worse on my left hand too, the right hand they don't seem to get too bad, I'm right handed. Me too, figure I'm squeezing the rear brake a lot harder because I'm not cool enough to do up to fronts accurately I always go for gloves that have just a little padding along the callus zone. Foam grips were good too but my hands are just too sweaty to not be wrapped up. Quote Link to comment Share on other sites More sharing options...
ArcticBeast Posted April 16, 2021 Report Share Posted April 16, 2021 Used to get huge callouses, a pair of cable snips used to make quick work of getting rid of them, just have to be careful not to take too much of. Quote Link to comment Share on other sites More sharing options...
Richie612 Posted April 16, 2021 Author Report Share Posted April 16, 2021 1 hour ago, marg26 said: Quarter a sheet of medium/fine grit paper, wrap it around a pencil, and sand the excess down. Wear gloves when the callouses are worst. I always get them worse on my left hand too, the right hand they don't seem to get too bad, I'm right handed. They're the same on both hands and I'm right handed. Quote Link to comment Share on other sites More sharing options...
Richie612 Posted April 16, 2021 Author Report Share Posted April 16, 2021 1 hour ago, isitafox said: Foam grips are amazing, otherwise I'd recommend a corn razor (can get from chemists) and pumice stone. My hands are constantly sore and getting hammered from pullup bars and that's what I use. Think I'll try the foam grips, they can't be as harsh as the grips I'm using at the moment. Quote Link to comment Share on other sites More sharing options...
Richie612 Posted April 16, 2021 Author Report Share Posted April 16, 2021 1 hour ago, bikeperson45 said: Me too, figure I'm squeezing the rear brake a lot harder because I'm not cool enough to do up to fronts accurately I always go for gloves that have just a little padding along the callus zone. Foam grips were good too but my hands are just too sweaty to not be wrapped up. Both palms are the same and I always wear gloves. They're quite thin 661 ones as I prefer thin gloves because you can feel more. Quote Link to comment Share on other sites More sharing options...
La Bourde Posted April 16, 2021 Report Share Posted April 16, 2021 My best advice: ride even more and don't stop riding! Don't use to aggressive grips (pattern too present). Also wash your gloves as much as possible, so that dust,sand is removed from the glove surface. 1 Quote Link to comment Share on other sites More sharing options...
Richie612 Posted April 17, 2021 Author Report Share Posted April 17, 2021 11 hours ago, La Bourde said: My best advice: ride even more and don't stop riding! Don't use to aggressive grips (pattern too present). Also wash your gloves as much as possible, so that dust,sand is removed from the glove surface. Oh I'll keep riding, no problem there mate. I'm sure they will settle down at some point. My gloves are always kept clean and they very rarely get dirty just a bit sweaty. Maybe it's my practice routine of up to front and back that's doing it. Either way I'm going to invest in some softer foam grips. Rich Quote Link to comment Share on other sites More sharing options...
Swoofty Posted April 17, 2021 Report Share Posted April 17, 2021 +1 for the pumice stone, of course, you have to actually use it though! Get one of the ones that's round-ish, not the rectangular ones. Use it at the end of your shower/bath when your hands are nice and warm and use it with the hot/warm water running over your hands and the stone. Keep the whole process warm and wet. Get in the habit of using it and you'll be much happier. I use foam grips and gloves, but there's no real magic bullet there. With summer approaching, you'll be doing more hot and humid rides and that's how your skin will react regardless. It's more important to have good bar feel than minimize calluses. 1 Quote Link to comment Share on other sites More sharing options...
Richie612 Posted April 17, 2021 Author Report Share Posted April 17, 2021 6 hours ago, Swoofty said: +1 for the pumice stone, of course, you have to actually use it though! Get one of the ones that's round-ish, not the rectangular ones. Use it at the end of your shower/bath when your hands are nice and warm and use it with the hot/warm water running over your hands and the stone. Keep the whole process warm and wet. Get in the habit of using it and you'll be much happier. I use foam grips and gloves, but there's no real magic bullet there. With summer approaching, you'll be doing more hot and humid rides and that's how your skin will react regardless. It's more important to have good bar feel than minimize calluses. So essentially you're saying I need to go to the chemist and ask for some man-up pills . Should have just said that to begin with haha. I'm old enough not to be offended by what people really mean . Quote Link to comment Share on other sites More sharing options...
Swoofty Posted April 17, 2021 Report Share Posted April 17, 2021 Curious to know how that trip to the chemist would play out... ;-) No put down intended on the pumice. I use one quite often and I also forget to use it quite often. Quote Link to comment Share on other sites More sharing options...
