Kɴᴜʀʟᴇᴅ rims. . .
Alessandor
On 15/03/2021 at 5:09 PM, Alessandor said:
...İnteresting ‽
https://www.highcube.org/rim-knurler
This was tried years ago on the American forum. It didn't work as well as a grind because the edges weren't as rough as what you would get with a grind. It provides excellent hold but not so good bite.
EDIT: actually this might be the article from the past
Edited by Canardweb
1 hour ago, Canardweb said:
Questo è stato provato anni fa sul forum americano. Non ha funzionato bene come una molatura perché i bordi non erano ruvidi come quello che si otterrebbe con una molatura. Fornisce un'eccellente tenuta ma non una buona presa.
EDIT: in realtà questo potrebbe essere l'articolo del passato
OK (Y)
Thanks !
  • 2 weeks later...
Remember the plazmatic rim coatings? Ha, that article is an awesome read
I always wanted to grind a rim and then have it re-annodized. Since the anodize is so hard it should make it last a lot longer, but I don't think it's thick enough to round to edges significantly. Any engineery thoughts?
Edited by cwtrials
  • Like 2
Interesting idea!
I think it would improve grind life but not proportional to the cost. Anodising still wears off rims pretty quickly - and that's with full surface area.
Before anodizing the material will need an etching pretreatment, this may "dull'en" the grind.
