matt slegg Posted January 13, 2021 Report Share Posted January 13, 2021 Just watched an old video on Flipp on his Alias 20.1. How is he running a rear Hope hub? Anyone know? Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted January 13, 2021 Report Share Posted January 13, 2021 https://www.tartybikes.co.uk/20_inch_frames/alias_202_with_headset/c36p13201.html?pos=700&search_params=YTo3OntzOjEyOiJjYXRlZ29yeV9pZHMiO2E6MTp7aTowO3M6MjoiMzYiO31zOjE2OiJjYXRlZ29yeV9yZWN1cnNlIjtiOjE7czo4OiJrZXl3b3JkcyI7czowOiIiO3M6OToiYnJhbmRfaWRzIjtOO3M6NDoibW9kZSI7czozOiJhbGwiO3M6NDoic29ydCI7czo5OiJwcmljZV9hc2MiO3M6MTA6ImNvdW50cnlfaWQiO3M6MToiMSI7fQ%3D%3D The frame comes with 135mm spacing. Edit - I'm stupid and don't read things properly. Quote Link to comment Share on other sites More sharing options...
aener Posted January 13, 2021 Report Share Posted January 13, 2021 (edited) 8 minutes ago, Al_Fel said: https://www.tartybikes.co.uk/20_inch_frames/alias_202_with_headset/c36p13201.html?pos=700&search_params=YTo3OntzOjEyOiJjYXRlZ29yeV9pZHMiO2E6MTp7aTowO3M6MjoiMzYiO31zOjE2OiJjYXRlZ29yeV9yZWN1cnNlIjtiOjE7czo4OiJrZXl3b3JkcyI7czowOiIiO3M6OToiYnJhbmRfaWRzIjtOO3M6NDoibW9kZSI7czozOiJhbGwiO3M6NDoic29ydCI7czo5OiJwcmljZV9hc2MiO3M6MTA6ImNvdW50cnlfaWQiO3M6MToiMSI7fQ%3D%3D The frame comes with 135mm spacing. That's the 20.2. He's specifically asking about the 20.1, which was sadly 116mm. My originals were 135 so I could run a Hope, but the bosses at Alias felt there would be a larger appeal to 20" riders if they didn't also have to change their hub/back wheel to experiment with a new geometry, so they made the production model 116mm spaced. My DIY frames and the black prototypes were spaced at 135mm, if they're the videos you watched. The production 20.1 (dark green and grey) frames were spaced at 116mm. I had a Hope custom modified by a friend to fit this spacing. The 20.2 is spaced at 135mm, specifically because of so many people wanting to run Hopes. If you have a 20.1, to run a Hope you will either need: A talented friend to customise a 135 hub for you (from what he told me, it's doable but not a particularly simple task, especially if you want the disc tabs to still be functional) To miraculously find one of the handful of hubs that have already been modified (I only know of about 5 that have been done, including mine, and I suspect people will be wanting to hold on to the ones they got done!) Or find an alternative - a front freewheel setup, or a different freehub that comes in 116mm. I've never investigated other freehubs so I'm afraid I can't advise on likely candidates. Edited January 13, 2021 by aener 1 Quote Link to comment Share on other sites More sharing options...
Matt24. Posted January 13, 2021 Report Share Posted January 13, 2021 Halo do a 110m spaced hub with disc mounts and a splined sprocket fitting. Considered it when I was weighing up whether to keep the 20.1 or chop it in for the 20.2. I ended up going 20.2 as didn’t want to be the one to see if the hub would stand up to trials. But is is an option!! https://www.halowheels.com/shop/components/hubs/mxr-supadrive-disc-hub/ 120 engagement points. Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 13, 2021 Report Share Posted January 13, 2021 I've got a Supadrive on my MTB and it is absolute dogshit. I believe that hub will use the same engagement system - I wouldn't want to use it for trials. The main issue I've got is freehub bearings on my MTB, but it skips repeatedly every ride too (this is across 4-5 different freehub bodies that I've used, with fresh pawls/springs on each). Whenever I'm putting a lot of power down on a climb, I half expect to eat shit immediately. I wouldn't want that in the back of my mind going for a gap, as an example. 1 Quote Link to comment Share on other sites More sharing options...
matt slegg Posted January 13, 2021 Author Report Share Posted January 13, 2021 Thank you all so much, really helpful. This is why I love this place! I guess Ill just go with the freewheel on the front for ease. Quote Link to comment Share on other sites More sharing options...
Matt24. Posted January 13, 2021 Report Share Posted January 13, 2021 3 hours ago, Mark W said: I've got a Supadrive on my MTB and it is absolute dogshit. I believe that hub will use the same engagement system - I wouldn't want to use it for trials. The main issue I've got is freehub bearings on my MTB, but it skips repeatedly every ride too (this is across 4-5 different freehub bodies that I've used, with fresh pawls/springs on each). Whenever I'm putting a lot of power down on a climb, I half expect to eat shit immediately. I wouldn't want that in the back of my mind going for a gap, as an example. This is exactly why £500 on frame and wheel rebuild was preferred to my teeth!! Quote Link to comment Share on other sites More sharing options...
