Back Wheel Control
Hackskb
Looks good (Y). One big change I found when first learning was stopping having locked brakes so that I was effectively 'rocking' up onto the back wheel. The way to do it is to start in a balanced track stand (or small correction hops or front/rear wheel shifts) and then release the back brake and put a bit of power through the cranks to raise the front wheel and basically drive the rear wheel forwards to bring it beneath your centre of gravity in order to get into the backhop position. By doing it that way you're in full control and using the motion of the wheel to maintain balance. If you just rock up with locked brakes you're locked into judging where you end up by where your weight ends up and also fighting the left/right momentum that will throw you off balance.
The timing is critical for releasing the rear brake, inputting some power into the cranks, pulling up with your arms and then finding the balance point and then applying the back brake ready to start hopping as needed. Trying to stay more relaxed also helps as being stiff will make it far harder to maintain balance and also tires you out far faster. Once you're happy with that technique it's only a small step to repeat the 'brake off, crank impulse, brake on' which is required to start forward pedal kicks. I think the important thing there is that you will want to allow the front wheel to drop just a little as a sort of preload so that when you put the pedal kick in the rear wheel is accelerated back underneath you and back beneath your centre of gravity.
  • Like 3
