Tyre Insert INSIDE Inner Tube = Puncture Protection for Trials?
Max F
1 hour ago, Maintenance Justice said:
I applaud his enginuity but Tannus came up with a solution for use outside the tube that looks a bit less faff. I'd be interested to see how it works for trials though, might be too rigid.
https://tannus.co.uk/armour-homepage#select-armour-size
From my personal experience and some feedback I've read on Tannus Armour:
The problem with inserts outside of the tube is that the foam gets squished into a very thin layer over time and ends up providing close to no protection. And Tannus Armor is a lot heavier than a DIY insert.
  • Like 1
55 minutes ago, Stephen Morris said:
I don’t understand what you’ve done and why you’ve done it... and I’ve now watched it three times.
You seem to have cut a tube apart and stuck patches inside it. How, I don’t understand?!?
I put a foam insert inside the tube to prevent snakebites. Like the ones you put in tubeless wheels.
