Rip Posted September 8, 2020 Author Report Share Posted September 8, 2020 25 minutes ago, ben_travis said: I'd recommend the 9.p pads to help reduce pad rock. They are the single pad version (MT5 style) yeah? Same compound as MT7 8.p? Quote Link to comment Share on other sites More sharing options...
Swoofty Posted September 8, 2020 Report Share Posted September 8, 2020 The BBB BBS-371S has been the holy grail for MT5/MT7 brakes for me. The pad compound seems to be somewhere between Magura's 9.P and Trialtech's compound and you get the best of both worlds in that they are MT5 style, but with MT7 retaining pin holes. I only use these on the rear; the 9.P is great up front and pad knock eventually goes away. Bike24 has the BBBs. Quote Link to comment Share on other sites More sharing options...
Rip Posted September 8, 2020 Author Report Share Posted September 8, 2020 Just now, Swoofty said: The BBB BBS-371S has been the holy grail for MT5/MT7 brakes for me. The pad compound seems to be somewhere between Magura's 9.P and Trialtech's compound and you get the best of both worlds in that they are MT5 style, but with MT7 retaining pin holes. I only use these on the rear; the 9.P is great up front and pad knock eventually goes away. Bike24 has the BBBs. Thanks, I'll definitely keep those in mind but first I want to try the standard 9.P pads as a kind of baseline. Quote Link to comment Share on other sites More sharing options...
Rip Posted September 8, 2020 Author Report Share Posted September 8, 2020 If I decide I need a little more bite in the rear then I'll give a set of those a go. Quote Link to comment Share on other sites More sharing options...
cookie70 Posted September 9, 2020 Report Share Posted September 9, 2020 I went through similar process on my 24" bike that has MT7 brakes. I wasnt happy with the stock magura performance, pads/rotors most likely contaminated as the bike is 3rd hand etc etc.. So I put on 203mm shimano rotors, after seeing what Ali C runs and got Jitsie pads. Now they do have insane stopping power but any thoughts of modulating a manual etc is just beyond my ability with them and I guess running the bigger rotors exacerbated it. I have literally spent hours trying to get the pads to not rub and be noisey. I've pretty much given up with these Jitsie pads. Its great to see some suggestions for pads that work well in the MT7 brake. Will see if I can get some 9P locally and start again. 1 Quote Link to comment Share on other sites More sharing options...
Swoofty Posted September 9, 2020 Report Share Posted September 9, 2020 I've been very impressed with the abilities of a Magura MT4 up front with 203 rotors. I ran MT5s for years up front, but the MT4 gives you plenty of power (for the front), but with great modulation. The MT4s also retract the pad farther than the MT5/7s so less rubbing in general. Plus, there's quite a few aftermarket MT4/6 pads to choose from, although the 9.Ps are great pads all around. The MT8s have been discontinued and you can find them for pretty cheap now (comparatively). I've always wanted to try one of those up front. 2 Quote Link to comment Share on other sites More sharing options...
Rip Posted September 9, 2020 Author Report Share Posted September 9, 2020 3 hours ago, cookie70 said: I went through similar process on my 24" bike that has MT7 brakes. I wasnt happy with the stock magura performance, pads/rotors most likely contaminated as the bike is 3rd hand etc etc.. So I put on 203mm shimano rotors, after seeing what Ali C runs and got Jitsie pads. Now they do have insane stopping power but any thoughts of modulating a manual etc is just beyond my ability with them and I guess running the bigger rotors exacerbated it. I have literally spent hours trying to get the pads to not rub and be noisey. I've pretty much given up with these Jitsie pads. Its great to see some suggestions for pads that work well in the MT7 brake. Will see if I can get some 9P locally and start again. I'll let you know what the 9.P pads are like in a few days when they've arrived and been bedded in. I can only imagine what Jitsie pads with 203mm rotors feels like! Quote Link to comment Share on other sites More sharing options...
