kaybs41282 Posted May 31, 2020 Report Share Posted May 31, 2020 Is it possible to get the coust pads for v brakes? I can't seem to find them so am I right in thinking they're just for hs33. Cheers Chris Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 31, 2020 Report Share Posted May 31, 2020 That's right. You could get some 10mm ones and transplant the material into Heatsink, TNN or other backings though. Quote Link to comment Share on other sites More sharing options...
kaybs41282 Posted May 31, 2020 Author Report Share Posted May 31, 2020 Awesome cheers Adam Quote Link to comment Share on other sites More sharing options...
Tony Croft Posted June 1, 2020 Report Share Posted June 1, 2020 I run coust pads on a v mate just buy some adapters. https://www.rockandrollbikes.com/tensile-magura-brake-pad-converters.html 1 Quote Link to comment Share on other sites More sharing options...
craigjames Posted June 1, 2020 Report Share Posted June 1, 2020 4 hours ago, Tony Croft said: I run coust pads on a v mate just buy some adapters. https://www.rockandrollbikes.com/tensile-magura-brake-pad-converters.html Problem you'll have with running those and the coust pads, which are already very thick, is they'll add even more width to your brake set-up and limit the width of rim you have. You'll want decent CNC backings , then with some patience, time, a sharp stanley and some epoxy; you'll end up with some awesome vee pads. Or maybe just pick up some TNN Vee pads? 2 Quote Link to comment Share on other sites More sharing options...
Tony Croft Posted June 1, 2020 Report Share Posted June 1, 2020 Its worth a £4 gamble.worked for me Quote Link to comment Share on other sites More sharing options...
kaybs41282 Posted June 1, 2020 Author Report Share Posted June 1, 2020 Cheers fellas. I might give that a whirl but as a substitute how do the TNN ADV pads compare? Quote Link to comment Share on other sites More sharing options...
Canardweb Posted June 1, 2020 Report Share Posted June 1, 2020 Just send an e-mail to Michel Coustellier asking for some pad material: michel.coustellier@voila.fr In French preferably! 1 Quote Link to comment Share on other sites More sharing options...
SamKidney Posted June 4, 2020 Report Share Posted June 4, 2020 On 01/06/2020 at 5:48 PM, kaybs41282 said: Cheers fellas. I might give that a whirl but as a substitute how do the TNN ADV pads compare? ADVs are great. 1 Quote Link to comment Share on other sites More sharing options...
