justinlock Posted May 29, 2020 Report Share Posted May 29, 2020 Hi all, I'm wondering if anyone has either used or knows if I could use the Magura MT5 e-stop brake set on a trials frame. Want something that is powerful and sharp but won't break the bank too much. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 29, 2020 Report Share Posted May 29, 2020 The e-Stop brakes are the same as the standard brakes, just with their 'Sport' pads in them. In terms of fit and performance, the actual brake itself is no different to the regular MT5s (which are fine on trials bikes). 2 Quote Link to comment Share on other sites More sharing options...
Private Repress Posted June 4, 2020 Report Share Posted June 4, 2020 I’ve got some MT30 brakes for sale if you are interested? Same power at the MT5s Quote Link to comment Share on other sites More sharing options...
justinlock Posted June 4, 2020 Author Report Share Posted June 4, 2020 1 hour ago, Private Repress said: I’ve got some MT30 brakes for sale if you are interested? Same power at the MT5s Sorry bud, not at the moment. Gotta save for the rest of the frame, new front wheel etc. If they're still available when I can, then I'll probably have them Quote Link to comment Share on other sites More sharing options...
justinlock Posted June 17, 2020 Author Report Share Posted June 17, 2020 So on a related note, does anyone know if I can still swap the piston caps on the MT5 e-stop's? Want something that stands out a little more. Quote Link to comment Share on other sites More sharing options...
Private Repress Posted June 18, 2020 Report Share Posted June 18, 2020 On 17/06/2020 at 1:14 AM, justinlock said: So on a related note, does anyone know if I can still swap the piston caps on the MT5 e-stop's? Want something that stands out a little more. Yep, the little plastic inserts will fit in just fine Quote Link to comment Share on other sites More sharing options...
justinlock Posted June 18, 2020 Author Report Share Posted June 18, 2020 2 hours ago, Private Repress said: Yep, the little plastic inserts will fit in just fine Awesomeness Quote Link to comment Share on other sites More sharing options...
